wheel center caps...need new ones or paint>?
Do these look good repainted>? Using what paint>? Or am I better off just getting new ones? I cannot seem to find them anywhere in good condition...not even on ebay...
thanks
"Never ask a barber if you need a haircut" - Warren Buffett 2006 Merc R350 (wife's car) 2003 M3 SMG coupe (for now) 1996 SVX LSI 28k 2004 Burberry Jaguar electric car (daughter's car) coming soon... 2006 Noble m400 |
I have the same issue.... I'd like to find some automotive spray that matches the silver...
1994 SVX LSi - Black / Beige - 139k miles SOLD! ![]() 1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride. 2004 Chevy Silverado Z71 - Blue LT2 luxury package |
Originally posted by aredubjay:
Also, for those who need to paint their center caps, I found that Plasti-Kote Import Color paint code Datsun 5412 matches the 94-97 silver wheels perfectly. Also, for the 92 "gray" wheels, the color "Burnished Silver" works well. I was a little upset with the Burnished silver when I first painted them, because it looked just a little darker than the wheels themselves. Then, when I bought my second 92, it had brand new centers and they look just slightly darker than the wheels, so, I guess I chose the correct color. Both of these colors should be available at Advance Auto or Autozone. The thing to do is to sand the old caps down to the yellow, or very close. Then, "mist" them with XIM sealer/primer/bonder (available at most hardware stores, Lowes or Home Depot). I say "mist," because if you put a heavy coat on them, they immediately "blister" and the bonder gives you problems. After you've misted them with the bonder, let them set for a day for a good "cure." Then, paint. I used toilet paper tubes to sit the caps on for easy painting. Spray the caps as directed. If you're adventurous, you can try painting the "Subaru" in the middle black, by thinning some black paint, and using a very small brush to apply the paint, then "tilt" the cap to allow the paint to flow into the letters (I, by the way, was NOT adventurous). My caps have been painted for two years now, with no signs of wear .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Don't your center caps also say "SVX" instead of "Subaru"? How did you do that?
Gene See post #53 http://www.subaru-svx.net/forum/showthread.php?t=40674
Basically, he roughed up the outer edges of all of the letters SUBARU with a Dremel tool and filled them in with epoxy. He layered it so that it was higher than the top of the center cap and then sanded it down when it was dry to the original contour. A little body filler putty to fill in any imperfections left after sanding and then a few coats of automotive primer. When I sent my wheels to Transwheel for powdercoating, they refinished my center caps in matching acrylic lacquer with an acrylic enamal clearcoat. So now I had beautiful silver wheels and matching BLANK center caps. I had created an .eps version of the SVX logo on my computer and scaled it to the size I wanted. I then took it to a sign shop, who computer-cut them out of silver (high-performance) automotive vinyl. The high performance stuff is thinner and holds up much longer than the regular stuff) I made a template of the center cap so that each decal was applied exactly on center. They have been on for almost 5 years and are still perfect in every way. I still have a few spares in case they get damaged and I have to replace them. ![]() They are very subtle and the color and metallic is a very close match to the wheel itself. Under different lighting conditions they appear and disappear. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-24-2007 at 08:51 AM. |
That would be awesome with the SVX "Horns" from the JDM Badge. Anyone have an .eps of the SVX "Horns"? Doug
In the hood emblem it looks great for two reasons. The first is that it is three-dimensional and has depth. The second is that the small SVX logo between the horns stabilizes it and also gives it a direction (You know where the top of the logo is) That is why Dayle's floor mats could not compare. The SVX part of the Alcyone logo is too small to be cut for center cap emblems. The horns look flat and dead when reduced to one dimension and you cannot be sure which is the top or bottom as they rotate. When they horns are viewed upside down, its resembles a sort of misshapen Acura logo (see the attachments) The SVX logo was always flat and without dimension, so that this design worked for the center caps. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-24-2007 at 08:28 PM. |
I was just curious:
why do you pictures of the Alcyone horns not have the 'SVX' in between the tips of the horns like my emblem? is that a difference between model years or 'old stock' badges or somesuch? I love the idea of expoying in the center caps, they're the only thing still giving my car away as a subaru... i've convinced most stupid people that 'Alcyone' was a rare brand of imported italian/japanese concept cars ![]() ![]() ![]()
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
Just using the horns, you would not know which way was up. Having the SVX in there tells you which way the logo is supposed to be seen. As I said, the SVX portion is too small to be computer-cut as part of the center cap logo. All you could have cut were the "horns". Sorry for the confusion... .
make it a group buy and make it worth it...
Following John, I have sanded, filled in, and painted my center caps.
I used a Bondo Repair Kit (which is a polyester resin) to fill in the "subaru" on my center caps. Since I couldn't find the Burnished Silver or Plasti-Kote Import Color paint code Datsun John recommended, I used my fairly new (5 year old) center cap to color match the silver (deciding on Dupli-Color T191 Ultra Silver). I Sanded, Filled, Painted and then followed with several layers of clear. They ended up being an almost exact match to the original cap. The funny part was that when I put them on my SVX.. they were all lighter than the rim! (Including the original which I never noticed until then. ![]() side note: I put the SVX logo on my painted calipers. I think it looks neat while serving no real purpose and will probably never be noticed by anyone but me...
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
I took a new picture of my painted caps with the SVX logo - which I copied from svxcess.
![]() I got my logos from Billy : nascar_junkie1 through eBay. p.s. I didn't put clear coat on top of the logos - as per your instruction, John
Marisa,
The caps look GREAT!!. They couldn't have been gone better if I had done them for you myself. Talking to you on the phone about how you did them, the procedd was correct in every way.The logos seem to be a little less subtle than mine, but they needed to stand out just a little more to compete with your new red paint. You definitely are not a woman to sit back and leave things alone. Whether sanding and refinishing your headlights, chasing down a new source for floor mats, or filling your own center caps, you possess that enthusiasm which makes this network shine. Speaking of shine, once you discover the Dremel tool, your automotive life will a lot less dull. Its an addictive thing, so be careful. Once again, a great job! Are you going to do a write-up or a How-to on how you did these? I am sure Billy (nascar junkie) still has your graphics file for the centers for those who want to do this project. I am looking forward to seeing them (or at least you) at Reading IX Speaking of Reading IX, don't forget the "10th Tee Shirt Challenge"... less than 29 weeks ![]()
![]() Here is the final photo. I had a "photo shoot" today and took a picture of wheel completed to give you an idea of how they look typically. I'm pretty happy with the result. ![]() Yeah, I'll pretty much try anything that I can't kill myself doing... or at least, I'm fairly certain I won't die trying.. lol I could write a how to but I think my long process might annoy most. I put several coats of silver and clear, sanding in between. Maybe once the Gallery opens up to everyone, I will write something up. ![]() TTYS
