According to memory(the last time I had the gauge cluster out) those switch clusters are "one peice".
Meaning they are all housed in one large peice of plastic. If there is a button assembly IN there I'm sure it could be made to function. Or at least it could be made to "push", but I don't think there are any contacts, or "wiring" in there. Does anyone have any idea, or pics, of JDM or Euro models? Do they have switches there? I just cut a small hole in the back of the coin holder to run the wires through, and affixed a generic switch in there. But of course I also have a parts car if I change my mind. It of course doesn't look stock, but nobody can see it behind the steering wheel anyway.
Matt! 92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride! 83 Honda Magna v45 "Grendel" *Free after mail in rebate |
Doesn't look like it...
http://www.subarusvx.com/images/carp...nterior058.jpg And yeah, they're one piece. I was just kinda hoping or something, I guess. Heh. EDIT: Was driving home from picking up food (I always get revelations while driving, haha) tonight, I thought about the JDM cars. They're the reverse of the USDM ones... so the switch cluster with the hazards and defroster and blank is on the left instead of the right. So that means... that the JDM cars have a right-hand cluster with three switches, right? They're not the same switches, but they have the same connector don't they? If they do... it shouldn't be too hard to swap the buttons across and use the last switch as a 'power' switch... But then I'd have to source a JDM switch cluster... Last edited by Nomake Wan; 06-04-2007 at 09:22 PM. |
The Euro and Canadian SVXes have heated-seat buttons in place of the coin holder. Might be easier to get than JDM buttons.
http://www.subaru-svx.net/forum/show...+heater+switch
Oh, there's an idea. And only $80 to boot. Well, we'll see.
How about taking out that dumb shift lock mechanism and mounting the power button where it is on the non-US models?
will this mod work on my usdm 96 svx?? or is only for obd1??
I don't think anybody knows Cruisen. Nomake was the first to try this mod in the US [at least, that we know of], although it is quite a number of years ago now that the mod was suggested.
Asked to guess, the TCU still has the power map inside, and the gearbox still sends the same signals to the inputs. So I would expect it to work for you. It is actually a very easy thing to try to achieve. Your only problem might be the light. Is yours one of the ones that does not light up on the dash when Power mode is engaged? If so, then you won't know till you drive it if you are in Power mode. Joe
Re: Power Mode Selection
Just posting to say I dug into my photos and found the ones I used for this thread, reuploading them to imgur. All the photos in the first post should work now.
a little bit of a bump, wondering if anybody has wiring pinouts or such, would like to disable my parking light switch and turn it into a power mode switch.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Based on the wiring diagram that I have, the switch connects "fuse block pin E8" to "fuse #21 (F/B pin D11) " or "red-wht" to "blu-red" Hope you can find the wires
DIY FTW! 1993 SVX 25th Anniversary Edition @+142k -Rebuilt Tranny @135k -Regasketed Engine @140k -Enkei Raijin 18x8.5, with 255/35/18's @140k -BC racing Coilovers (From STI's) @142k |
just curious , i tried to wire in the power mode mod (didnt work)
im a little confused seeing as the pictures are lhd and mine is rhd is the plug in the same spot (lower most plug of tcu) or ? the plug i pulled is a 20 pin plug with the 4th one being the only empty slot |
