Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 09-18-2006, 04:29 PM
AFBeefcake's Avatar
Subaru Swapper
Wrx 5 speed cluch. Which one should I run?
Looks like I should be getting a WRX trany this week end.
My question to you 5 speeders out there is what clutch should I run?
I see all kinds of different ones on ebay. Stage 1-5, racing clutchs.
I just want one that will work well and not brake the bank. My car has some basic mods on it. See my soundomain link for the full run down.
2005 Legacy GT
My WRX's Cardomain Page
Old 09-18-2006, 04:40 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
On my 6MT I just used the stock exedy set up. If I go froce fed in the future I'd prob. swap out but as it sits, the SVX's HP output is comperable to an WRX so there shouldn't be any issues.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 09-18-2006, 05:24 PM
Earthworm's Avatar
Meow!
I'm still running the stock WRX clutch. It won't slip unless you foolishly heat it up.
Old 09-18-2006, 06:13 PM
AFBeefcake's Avatar
Subaru Swapper
O, I thought some one said to use a stage 2 or something. So I should be ok with a stock replacement clutch.
2005 Legacy GT
Old 09-18-2006, 06:16 PM
Earthworm's Avatar
Meow!
If yours didn't come with a clutch (like mine) then go with stock or some form of stage 2. Remember that as clutch performance increases, ease of use decreases.
Old 09-18-2006, 06:25 PM
AFBeefcake's Avatar
Subaru Swapper
Something like this right.
http://cgi.ebay.com/ebaymotors/Exedy...28945793QQrdZ1
2005 Legacy GT
Old 09-18-2006, 06:29 PM
Earthworm's Avatar
Meow!
Sure. Also, don't forget about a flywheel. Do you already have something in mind for that?
Old 09-18-2006, 06:53 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
you should be fine with that clutch if you're not drag racing or attempting a burnout.
more importantly... have the flywheel machined! a stock wrx one is fine.
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 09-18-2006, 07:51 PM
AFBeefcake's Avatar
Subaru Swapper
Yes, I got a stock wrx flywheel on the way and a legacy mt drive shaft too.
I just need to find a mt starter and a master clutch.
I can't wait to drive my svx again.
2005 Legacy GT
Old 09-21-2006, 09:29 AM
I may be picking up a pedal box and clutch master... You interested??
Old 09-21-2006, 10:56 AM
AFBeefcake's Avatar
Subaru Swapper
If its a WRX clutch master, then yes. I already got a wrx peddle box a wrx slave clutch and I should have a wrx trany on sunday.
Also how backed up are you on making the 5 speed parts. I got all of the pieces ready.
2005 Legacy GT
Old 09-21-2006, 01:46 PM
i am in Philly almost always so I am leaps and bounds away from my shop. I will let u know if I cam but I doubt it
Old 09-21-2006, 02:12 PM
AFBeefcake's Avatar
Subaru Swapper
Its not something I would need done right away. The trany that I'm getting is going to need some work. If you can doing it some time in the next couple months that would be ok.
2005 Legacy GT
Old 09-21-2006, 10:23 PM
oh ok... I need to try and get about 7 or 8 X-members done but I just don't have the time or the cores. I have only done 7 or 8 of them to date and I think 3 or 4 sent me cores back... Anyway I will see what I can do
Old 09-21-2006, 10:46 PM
gest24's Avatar
#1 6MT In Cali
I admit, I'm one of the bastard X-member hoarders... My bad Tom, I've had a box sitting in my garage just for the X-member and the other misc. items you called dibs on.
RIP
84 VW Scirocco
02 WRX
