1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) ![]() socaleuro.com They like the flat 6... Check My New Homepage.. |
You my friend are a Godsend! Glad to see your enthusiasm and verve are back after summer! ![]() Chike
Thank Kerry, it was his idea, I am just trying to put the equal force of a blowen EG33 behind the project ![]() Tom |
Personally Tom, I'm of the opinion that Subiesport can go %%$# a WRX up the tailpipe. I sent them a letter inviting them to Reading 2 years ago even offered to pick their staff member up at the airport and provide them with an SVX for the weekend, no reply except they cut and pasted my letter.
Then there's the whole pathetic waste of trees that they've created. Absolutely no content, no real work done aside from replacing freaking parts. I guess WRX owners like that.
well Ben, I hear your plight. DOn't just expect things to change then. lets give them a 4-5 page spread about SVXi that would be a great start and maybe we can get it to focus on my than just imprezzas and bring out more of the subuaru line instead of refrigerator boxes
Tom |
The mag is def. tuned more towards the new Subie crowd. Hence the reason I'm totally behind Tom to show the crowd what we've done over the years. They've only been around a couple years and is a fairly new publication, if you look on their webpage or mayspace they give you the process for getting a feature done. Pretty much they accept free-lance work. Had you done a write up and pictorial of the Reading meet I'm sure they would've used it. Thats what Tom is trying to do, bypass having them do it for us and just submit it to them to do the photo layout and publish it.
I was talking to a guy at a local shop who told me he knew people that submitted their cars for the "Readers Ride" and would see it 6 months later. I submitted my stuff a week before Tom came to do the swap and 6 weeks later its in print. They have an interest in stuff other than the Impreza line. Its up to us to give them other stuff to publish.
Yeah, you're right they CARE about old stuff. ![]() Oh and if we submit stuff they'll print it? Hmmm.. They didn't print the SVX meet that I gave them all the details about 6 months in advance. At the time they even had a calender of events either on their site or in the waste of trees.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. Last edited by benebob; 08-29-2006 at 07:58 PM. |
Tom:
The best pictures I have of my car are in my locker. They are in the folders called wheels and Pocono2 (there are two folders by this name, but one has more and better pics). Following is the information on my mods: ECUTune Stage 2 v5; - Ecutune Perrin Air Filter - Perrin Rota Boost 17x8 - SubyDude 245/40-17 BFG g-Force T/A KDW-2 - Tire Rack Flowmaster SS cat, resonator, and Bullet muffler - Mufflex Muffler Center drilled and slotted rotors, semi-metallic pads and SS brake lines - Race Concepts Phenolic intake manifold spacers - Outlaw Engineering Koni inserts - Motorsport Warehouse Ground Control coilovers, Eibach springs 335 lb/in fr; 285 lb/in r Subaru OEM strut top-mounts - SubaruParts.com SVX Hunter modified strut bodies Urethane Swaybar Bushings - Energy Suspension Dayle's inlet B pipe, insulated - Motorsport Warehouse Tomstock Stage 3 v 2: 2004 WRX 5mt - Leesville Auto Recyclers WRX sgtarer - Leesville Auto Recyclers ACT clutch, heavy duty pressure plate and Streetlite flywheel - Prostreet Online Transmission linkage - eBay Driveshaft - ?? Crossmember - Tom's home-brew Shift knob - Momo Shot boot - Momo Group N mounts - Rallisport intake cams - Delta Camshafts Engine Gasket kit - SubaruParts.com adj fpr - eBay Waldbro fuel pump - eBay
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Perfect Dan!! all I need you to answe is one question more... I would love a roundabout figure of how much has been spent on the vehicle including initial purchase
Tom |
Dan, I need pics of your car clean!!! this is going into a national mag... do u really want pollen and sap all over it?!?!?!
Tom |
#28
#29
Reading all this impreza brewhaha was just what I needed to talk me out of picking up the #2 WRX! It is a great deal and the car is literally just like it was off the lot with nearly no miles... I'm not gonna buy a new car for at least another year... I have to keep my promise this time
![]() Well, I'll either try and paint it before I have to move, or have it done and then have the photos done... if you are interested. Its no "shotgun", but...
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? Last edited by Speedklix; 08-29-2006 at 10:49 PM. |
#30
Sent you a PM Tom. Let me know what you think or if you need anything else. Ryan and I are taking more pictures tomorrow hopefully I'll get some useable ones.
