Old 08-17-2006, 08:55 AM
min's Avatar
min min is offline
95 SVX L - New owner
Send a message via AIM to min
Question rear tail lights; tiny issue
I've just replace the water pump, timing belt and all that goes with it, so this question is so very small. The back tail lights seem to hold moisture in them. They look foggy. Is there a fix to this, or is it just insignificant? (let's hope this is all I face for awhile).
Old 08-17-2006, 10:01 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Failure of the lens seal to the body of the light is one possibilty. Could dry out the interior and apply a thin bead of silicone.
Gene
Gene and Ben
Old 08-17-2006, 10:03 AM
SubaSteevo's Avatar
No longer blue member
Take the lenses off and put a hair dryer to the bulb holes to dry it out until you are sure they're dry. Then reinstall and swap the gaskets so they are on opposite sides (or install new gaskets).
You can also drill a very tiny hole at the bottom of the lens.
-Steve
01' MSM Lexus IS300
Old 08-17-2006, 10:22 AM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Try the "search" function....
This topic has been covered several times, with multiple suggestions for getting the moisture out and keeping it out.
Try searching "tail lights condensation fix" or the like.
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 08-17-2006, 10:44 AM
Earthworm's Avatar
Meow!
My fix:
- dry them off
- put silicone on the gasket where it contacts the taillight
- put grease on the gasket where it contacts the body
- reinstall
Old 08-17-2006, 10:48 AM
min's Avatar
min min is offline
getting the lenses off
the lenses are impossible to get off without snapping them. any suggestions?
Old 08-17-2006, 11:08 AM
Earthworm's Avatar
Meow!
Don't have to remove the lenses, just the entire assembly.
Old 08-17-2006, 05:18 PM
oab_au oab_au is offline
Tail light condensation.
Had this problem, found this fix.
http://www.subaru-svx.net/forum/show...57&postcount=3
One Arm Bloke.
Tell it like it is!
Old 08-17-2006, 05:24 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Some people put them in an oven to melt the glue. I used a hot air paint stripper, but it's very difficult not to damage them in the process.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
