Electrical questions
My Svx left my wife stranded today and she calls to tell me it wont start. I get there hop in and it starts right up. She says all the dash lights came on then it died. I had the alternator rebuilt 3 yrs ago but the car has sat for most of that time, there is probably less than 3k miles on rebuild. I had the alternator mod but have since removed it due to advice posted here. What is going on?
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT |
Intermittent faults are the worst and you have one. The ignition switch has been shown to be a gremlin in this area.
Happens to me during winter, I tried cleaning my terminals and tighten the bolts on it (battery). Later i removed the starter alarm relay. it was sticking....
When it would happen to me I just took the key back out, opened the door. closed it. start again. DO not know why but it seemed to start. SVX ghost? Try this: have your car running, remove both connections to battery. if it dies. it might indicate to alternator isues. Please do not touch both terminals or hold them uninsulated. 12dc is a lot Last edited by dmnknightomega6; 07-27-2006 at 08:00 AM. |
I have heard/read things saying never to run a car without the battery, ie: don't disconnect battery while car is running. Supposed to be bad for the charging system or something to that effect. Anybody else heard of that ?
found a reference
http://www.troubleshooters.com/dont_...ct_battery.htm
Any "check engine" codes stored?
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 07-27-2006 at 10:12 AM. |
I had one alternator that did the dash lightup when it went bad in my wife's car. I swapped it into my car (which had the wiring mod) and it worked fine. Put it back in her car and no go (hers did not have the wiring mod)
Strange. I'd take the car to a local auto place and have them do a thorough alternator test. They will do it for free.
Im believing its a bad ground or connection somewhere because the car sat for 3 yrs. Im going to clean and check today. It has a new battery and Ive driven it about 700 miles since the trans swap. Like I said its here and there with the lights about every 4-5 days usually when its hot outside.
Mine did the exact same thing about 4 months ago. The battery and alternator had been replaced about 6 months prior to that. I had completed a trip of about 75 miles, and the car was still warm after only sitting for about 15 minutes. I got back on the road, drove about 2 miles, had to come to a stop at a light, and as soon as I stopped, the engine lights came on, and then the car died. However, I removed the key, put the shifter back in park, and started it again with no problems. The problem did not come back again, however, I did have my alternator die only 2 weeks ago. However, seeing as how the incident was seperated by almost 4 full months, I think they are probably unrelated.
Mattski 97 LSi Ebony Pearl 130k Midlife Crisis 93 Legacy Wagon 180k Training Wheels 98 Outback 180k 98 Dodge Durango 120k Ski Bus A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death. |
1) After driving, Use a volt meter on the battery while the car is off. Take note of the reading, after an hour check it again. If the voltage droped, then something is draining the battery.
2) If all is o.k, check the battery voltage before and after starting to see if the alt is working. (around 12V off, 14V on) 3) If the volt regulator isn't working properly, the alt thinks the battery is at full charge and won't continue to charge. 4) Also if the battery has a dead cell, it won't charge completly. Have the alt and battery checked in the car. |
