Gonna need a trunk, wing, two rear fenders, bumper (maybe just repaint), miscellaneous light parts; pretty much a whole rear clip. I'd milk the person who rear ended you for all they're worth.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Hoped you kick his ass
![]() I almost did to the lady that hit me but..... Shes a lady so i just said that i hope she die's a very slow and horrible death. I meant every single word. Last edited by 1320boy; 04-25-2006 at 09:47 PM. |
damage
<<two rear fenders>>
no rear fenders on an SVX. i'm afraid to say, i think there going to total it. how many miles are on it? |
I think they are going to total it also
![]() Sorry to hear. Glad no person was hurt
1991 SVX L JDM |
"oh my neck, my back!!!" stick with that story and get a new and improved SVX
Tom |
That looks alot worse than it really is. The impact went over the rear bumper so the rails and trunk floor are not damaged. As far as the rear quarters(fenders) go; the drivers looks to have no damage at all. As far as the passengers quarter, look for any buckles further down the quarter panel (like around the wheel well) If there is none, and the only damage is what you showed in the picture...read on
![]() Purchase the following parts...preferably the same color: Rear bumper cover trunk lid taillight set install the trunk lid and the driver side taillight remove your bumper cover At this point you may notice that the trunk lid may not close correctly because the part where the trunk latches on to is pushed back a inch or 2 and will need a "lil pulling" (Not to worry a body shop can easily take car of this) Now that you have the car looking more "whole" you will need one last part...that part of the passenger quarter which I marked in red in the picture. If you can find a parts car, have them cut that part off outside of my lines to give the body hope as much to work with as possible. When you have this.. head on down to a local body shop. Stay clear of the high priced flashy ones. A small business type will do. Look inside and if things look to be orderly and clean that usually indicates the type of work they will do on your car. Now what the body shop will do with your car is: First they will remove the damaged part of your quarter, cutting where I drew the doted line and drilling through the spot welds everywhere else. they will than do a lil pulling to have your trunk close correctly and aligned. They will cut off a portion from the part you provided matching the portion they removed from your car and they will weld that in place. Lastly they will apply a little bondo over the straight weld at the dotted line and than prime and paint your quarter providing that you found the other parts the same color. That is the cheapest Easiest way to fix your problem. the more expensive way is to replace the complete right quarter panel with a new one. Not sure how much they run for our car but usually they tend to be around $600 just the panel and than the labor could be in the thousands. In either event your car is far from totaled having received no real frame damage. ![]() |
![]() She was completly at fault so at least I wont be paying for anything. Quote:
Triumph,
Thanks for that detailed write-up! I think the hardest part will be to find a parts car out here. ![]() If it ends up not being totaled, I'm going to try and get a full repaint (something I've been wanting to do for a while). |
Mileage is irrelevant since cars are exempt after 7 years (that’s how it is in wisconsin anyway) What matters is the condition of the car and how rare it is. Case and point...Over at probetalk.com some guy smacked into a members car and turned this:
![]() into this... ![]() The initially wanted to total his car and give him something like $2500 he took them to court and got to keep his car and get a nice settlement |
That sucks!
Glad no one was hurt.
1996 SVX LSi Yellow/White fade custom paint. 1992 SVX LSL Pearl 1992 SVX LSi Ebony 1992 SVX LSL Silver - parts |
Oh man!!
-Ryu Links: 2004 Honda S2000 (2008~) 1992 Subaru SVX LSL Liquid Silver (2007~2008) 1996 SVX LSi Bordeaux Pearl (2006~) 2002 Lexus IS300 Sportcross (2005~) 1992 Subaru SVX LSL Pearl White (2001~2005) 1994 Mercury Sable GS (1999~2001) 1/43 Scale SVX Models [SIGPIC][/SIGPIC] |
Man that sucks...
![]() GUYS CUTTING AND REPLACING THE REAR FENDER WOULD MAKE THE CAR LOOKS WEIRD. that is fixable and the good bodyworker should be able to staighten in up... Check out my front fender after my last accident: ![]() Can you see the damage appearing in red circles? here is after fixing the fender: ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
![]() BTW, do you think this is the only damage this fender has sustained in the accident? I bet the rear fender is also bent somewhere in the middle. To straighten it out, the bodyworker should weld a chain to the side of the rear fender and use this device (whatchamacallit ![]() ![]()
wow,, i wish the best for you,
2008 evo x with sss package 430 hp 380 torque stock turbo with basic bolt ons 12.56 @ 109 fully weighted 3,500 lbs |
