AWD problem
I think I brought this up in an earlier thread, but can't find it at the moment...
My AWD doesn't seem to be working properly (big problem taking off in the snow!). Took it to a dealer for diagnosis and what they came up with was "error code 11 was present in memory"--"Line pressure duty solenoid malfunction". They sail more diagnostic time was needed....and that they needed to pull the tranny. Ouch! Any other suggestions? All ears.
Bruce Schwab Recovering solo ocean racer www.bruceschwab.com On land: 92 Ebony SVX, 188k |
most probably your solenoid C failing....80 buck part from subaru parts.com
Do the rear wheels kick in at all or are your fronts just spinning?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
They SEEM to kick in sometimes, but the fronts (or one front) will often spin for some time (seems to be mostly at low speed) without the rear kicking in.
Where is the Solenoid C located? I'd be happy to try that first before digging into the tranny to get at the duty soleniod!
All 3 solenoids are in the control assembly located above the transmission pan. I get them mixed up, but I'm almost certain sol C is one of the two solenoids you can get to by removing the pan without removing the transmission.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
Thanks Electro!
Is it labelled at all? What exactly does it look like? Got any pictures? Anybody?
Brian |
Looks like this; Harvey.
For reference: Code 11 = Solenoid A failure...nothing to do with AWD.
Usually it's caused by a failed resistor (between the battery and fender)
Thanks for the pic, but do you have one on of it on the car?
Brian |
That's a trick question. You have to take the back of the tranny (extension) apart to get at the solenoid.
"A" is by far the easiest.
Ok...next monday we are pulling the back of the tranny out to check out the Soleniod C and the clutch it engages. We think that the transfer (to rear axle) clutch might be burned out. Will report back on success or failure.
