Old 06-12-2005, 01:10 AM
92AWDSVX
Rotors..
Ok i need rotors on the car, and i have a set of cross and slotted rotors for 1st gen eclipse, will they fit??
Old 06-12-2005, 02:10 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
i want to say no.
Old 06-12-2005, 03:46 PM
92AWDSVX
Originally Posted by Matthewmongan
i want to say no.
hmm ok well anybody else?
Old 06-12-2005, 04:01 PM
the svx uses a 5-114.3 bolt pattern. the dsm uses 5-100.
no
Old 06-12-2005, 07:26 PM
michael's Avatar
michael michael is offline
What Potholes ???
I don't think that is true.
Wanted: Steering Wheel
Old 06-12-2005, 09:44 PM
thats what tire.com says when i looked it up. they could be mistaken.
i looked up 92 eclipse. is that the right year?
Old 06-12-2005, 10:13 PM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
Nope, email Ben at sales@raceconcepts.com he may just give you a sweet deal for being part of the network.... like Ive got in the mail for tommorrow.
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 06-13-2005, 07:54 AM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Plain and simple.... .NO, you can't use the rotors for a DSM.... Go to www.irotors.com or www.raceconcepts.com and get a set of their rotors... They are cheap and last a good amount of time ...
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 06-19-2005, 07:04 AM
svxnmx6
if eclipse rims will fit that car, why wouldnt the bolt pattern for the rotors?? only thing i would think could be off is the size of the rotor itself
Old 06-19-2005, 08:55 AM
The bolt pattern itself is easy. its the massive offset that our cars require thats the hard part and the DSM rotors not only have the wrong bolt pattern but are also smaller(diameter) and they might be slightly thinner which by alll means is a bad thing
Old 06-20-2005, 04:07 PM
svxnmx6
yes, thats what i was worried about was the diameter and the offset, but again, if eclipse rims fit our cars, how is the bolt pattern different??
Old 06-20-2005, 05:00 PM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
More to it than just bolt pattern
The Eclipse bolt pattern is the same, but I doubt much else is.
Following are critical to ensuring the correct fit:
Thickness of the rotor -28mm
Diameter of the hub mounting face
Rotor diameter
Distance from wheel mounting surface to rotor body
If any of these is off, the rotor will not work on the car. If any of these is off, the brakes will not operate properly, jeopardizing your safety, your passengers safety, as well as the safety of those on the road near you.
If you believe it will work, buy one and put the two side-by-side for a comparison. I don't believe they will interchange.
Todd
Down to none
Old 06-20-2005, 06:37 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Or you could just get slightly more involved and check one of the hundreds of online parts suppliers. Look up the part number for each car and see if they match.
If I recall correctly the Eclipse uses the typical old Mits style 'unusually thick' rotors.
Old 06-20-2005, 06:45 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Send a message via AIM to SVXer95
Don't forget the integral drum rear parking brake. I highly doubt that these rotors will fit. You are better off selling them and getting some that are the right design for the SVX. Raceconcepts are not only affordable, but good quality as well.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
80k miles. MBC + Chips. Relatively Stock
Old 06-20-2005, 08:29 PM
Yeah I just seen the drum brake is that for the parking brake or what? I just installed my new raceconcepts slotted rotors and how often do the shoes need replacing as Ive never seen this configuration.
