Rotors..
Ok i need rotors on the car, and i have a set of cross and slotted rotors for 1st gen eclipse, will they fit??
i want to say no.
the svx uses a 5-114.3 bolt pattern. the dsm uses 5-100. no |
I don't think that is true.
thats what tire.com says when i looked it up. they could be mistaken.
i looked up 92 eclipse. is that the right year? |
Nope, email Ben at sales@raceconcepts.com he may just give you a sweet deal for being part of the network.... like Ive got in the mail for tommorrow.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
Plain and simple.... .NO, you can't use the rotors for a DSM.... Go to www.irotors.com or www.raceconcepts.com and get a set of their rotors... They are cheap and last a good amount of time ...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
if eclipse rims will fit that car, why wouldnt the bolt pattern for the rotors?? only thing i would think could be off is the size of the rotor itself
The bolt pattern itself is easy. its the massive offset that our cars require thats the hard part and the DSM rotors not only have the wrong bolt pattern but are also smaller(diameter) and they might be slightly thinner which by alll means is a bad thing
yes, thats what i was worried about was the diameter and the offset, but again, if eclipse rims fit our cars, how is the bolt pattern different??
More to it than just bolt pattern
The Eclipse bolt pattern is the same, but I doubt much else is.
Following are critical to ensuring the correct fit: Thickness of the rotor -28mm Diameter of the hub mounting face Rotor diameter Distance from wheel mounting surface to rotor body If any of these is off, the rotor will not work on the car. If any of these is off, the brakes will not operate properly, jeopardizing your safety, your passengers safety, as well as the safety of those on the road near you. If you believe it will work, buy one and put the two side-by-side for a comparison. I don't believe they will interchange. Todd
Down to none |
Or you could just get slightly more involved and check one of the hundreds of online parts suppliers. Look up the part number for each car and see if they match.
If I recall correctly the Eclipse uses the typical old Mits style 'unusually thick' rotors.
Don't forget the integral drum rear parking brake. I highly doubt that these rotors will fit. You are better off selling them and getting some that are the right design for the SVX. Raceconcepts are not only affordable, but good quality as well.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
Yeah I just seen the drum brake is that for the parking brake or what? I just installed my new raceconcepts slotted rotors and how often do the shoes need replacing as Ive never seen this configuration.
