Old 09-24-2004, 08:41 PM
THAWA
no i'm not kidding, is there a reason you had to remove them?
Old 09-24-2004, 08:54 PM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
OK, here we go.
To get to the headbolts which attach the heads to the block (where the head gaskets live) you need to remove the "rocker covers" (a misnomer as the EG33 doesn't have rockers being a DOHC design) to remove the cams to get access to the head bolts to remove the heads.
Once he'd done that he took the heads to a machine shop to have them "skimmed" aka machined flat.
How's that?
Todd
Down to none
Old 09-24-2004, 08:58 PM
THAWA
ah, okay
Old 09-25-2004, 01:34 PM
Notall There
Thumbs up
Thanks wawazat! U r correct! Cant take the heads off without removing the cams! Not a nice job i can tell you!
Especially as the inlet cam gear is split in 2 sections & they're spring loaded together! :S
Phil,
Update: Engine's in, just gotts put the inlet manifold & a few little bits on now! Will be running sunday!
Old 09-25-2004, 03:14 PM
gl1674 gl1674 is offline
There is a threaded hole in the cam gears - you are supposed to bolt in there before removing the camshaft. The bolt will keeps the gears together and you would not have to deal with the spring.
Old 09-26-2004, 04:24 AM
Notall There
I know that NOW! didnt realise til i had them out! DOOH!
Phil.
Old 09-26-2004, 10:23 AM
Notall There
Thumbs up
right, all done, taken her for a drive & seems ok so far! gonna attempt a 50 mile trip home later !
1 question, how much does the temperature guage normally move when driving? mine is sitting level during town driving, & raises slightly when i speed up! But i've not had a chance to give it a real bootful to see if the temp guage shoots up like before?
Phil.
Old 09-26-2004, 01:02 PM
immortal_suby's Avatar
Thread Killah
The temp gauge should stay perfectly still during any type of driving if all else is ok. It might drop a hair when you turn on the AC
Locker Link
2015 BRZ Limited 6MT
Old 09-26-2004, 05:15 PM
Notall There
Talking
Ok Guys & Girls...........SUCCESS!
Head gaskets done, problem cured!
Drove it home from portsmouth tonight (about 50 miles) & it didn't miss a beat, temp guage stayed at 1/2 way, even with a quick blast down the bypass at 110!
Have posted all the pics i took in my personal locker, so if you want to see what your engine looks like inside take a look!
Phil.
92 SVX (94k) Claret
Old 09-26-2004, 07:27 PM
wawazat??'s Avatar
Thumbs up
Congratulations Phil! Great feeling, eh!
Todd
Down to none
Old 09-26-2004, 11:45 PM
Notall There
Yep, sure is Todd!
