Old 03-21-2004, 03:57 PM
oab_au oab_au is offline
Originally posted by immortal_suby
Update -
Changed tranny fluid and filter. Took a test drive.
Confirmed there is no slipping in 1st, 3rd, 4th.
Only slips in 2nd - and will slip throughout 2nd at any rpm if I stomp on it. It felt like it got progressively worse as the tranny got warmer.
I haven't heard of only 2nd gear going?
Brake band adjustment only controls shifts, right? So that wouldn't help me if it slips while in gear (tranny in 2, manual mode)
I'm puzzled.
Hi Matt, the brake band has to hold for 2nd and top. As it wears it will slip in 2nd at first, due to the higher load, If it keeps sliping it will slip in top gear also.
Do the band adjustment, nip the adjuster up, then back it off three full turns, this sets the right clearence.
One Arm Bloke.
Tell it like it is!
Old 03-21-2004, 04:32 PM
immortal_suby's Avatar
Thread Killah
Thanks a ton, Harvey - I'll try it then and report back the results.
Locker Link
2015 BRZ Limited 6MT
Old 03-21-2004, 06:24 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Harvey,
Okay, you've got me on this one... what does "nip the adjuster up" mean? (tighten it all the way down?).
Matt,
Any way you can take a picture or two of the adjuster and post them?
-Bill (thinking that he's going to need to do this adjustment soon, that or the TPS clean/adjust fix)
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-21-2004, 06:42 PM
Thread Killah
I'll try to snap a picture - it is buried pretty deep in there but I should be able to get a shot of it.
I assumed Harvey meant tighten it all the way down - maybe I'll wait for clarification before i touch it.
Locker Link
Old 03-21-2004, 06:48 PM
lee lee is offline
I'm not Harvey, but yes...he meant tighten it all the way down. If you search you'll find the spec, it's like 6.5 ft lbs (which is impossible to set while installed). Then back off three full turns (360 degrees each) of the square adjuster.
a small tip, take off the rubber vent hose at the top of the tranny that loops & ends at the dog-bone. Makes it possible to swing the adjusting wrench farther.
Old 03-22-2004, 09:02 PM
Thread Killah
Holy crap - it worked. The brake band adjustment worked.
I still can't believe it.
Figures - bought a battery for the POS celica backup car today, installed that, then did the brake band.
Still skeptical, we'll see how it does for the next couple days, but I beat the snot out of it just now and it is shifting nice and firm again.
/note to anyone else adjusting the brake band. Disconnect the battery first - had a nice shower of sparks grounding the brake band locknut to the starter with a 17mm wrench. Taking off the intake boot provides alot more room and a clear view to do the job.
Many thanks to Harvey, Randy, all others, hopefully it will keep working.
Locker Link
Old 03-22-2004, 10:00 PM
Oh yea of little faith*
Don't worry Mat, it will be OK now.
This is just an adjustment that should have been included in the perodical servicing of the car, like every 60 thousand miles, by the dealer. The number of gear boxs that have been destroyed, because Subaru neglected to include it .
It seem to be the way the auto servicing industry is going, don't do any skilled work, just replace and charge.
One Arm Bloke.
Tell it like it is!
Old 03-23-2004, 08:32 AM
SVXRide's Avatar
Matt,
Congrats! I think you just earned your SVX Field Service badge
Were you able to take any pictures? I'm thinking that I need to give this a try before Reading!
-Bill
Old 03-23-2004, 05:29 PM
Thread Killah
Sorry, didn't get any pics this time. I can probably snap some though to give you a general idea of what to look for.
Locker Link
Old 03-23-2004, 10:50 PM
SVXRide's Avatar
Matt,
That would be great. Thanks.
-Bill
