Old 12-03-2003, 08:43 PM
lee lee is offline
A recent post made me think a little
A recent post asking about tire sizes, and a reference to a Miata site, made me do some thinking & a tiny bit of work.
So, I made a couple of Excel spreadsheets, then published them as interactive web documents.
Can somebody try one of them and see if they work for you. I would be especially interested in both PC and other type computers (Macs, Linux, etc) and even more so if you don't have Excel. They work for me but.....not so sure about my skills. If they work I may try to pretty them up. One does the tire size comparo thing, the other determines how many times you would have to do a drain and refill to get some percentage of clean fluid.
Anyway if interested look here:
http://www.subaru-svx.net/photos/user.php?lee
Old 12-03-2003, 09:38 PM
arondale
didn't work for me.
i'm on my mac now using safari browser, which strictly follows w3 consortium standards.
have not tried my p4 yet.
arondale
Old 12-03-2003, 10:16 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
To use this Web page interactively, you must have Microsoft® Internet Explorer 4.01 Service Pack 1 (SP1) or later and the Microsoft Office XP Web Components.
PC - WinXP Pro, IE
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 12-03-2003, 10:49 PM
mntnsvx
Spreadsheets
Worked for me.
PC: Centrino (Intel P4 equivalent, but made for laptops), Windows XP, Office XP.
I liked the tire replacement spreadsheet, very useful.
However, there is an error in the logic of the fluid replacement sheet. The math is fine, but it assumes that the same percentage of the residual fluid leftover is replaced the second time, and there is no way of being sure of that. That last quart may be solid in the bottom of the pan--you have no way of knowing that 70% of the non-replaced 3 quarts are replaced in the second fluid exchange. Or the third, or the fourth...
The only way to make sure 100% of your fluid is replaced is to do a complete drain from the bottom of the pan, and have it completely flushed, then replace with completely new fluid.
Kevin
Old 12-03-2003, 11:09 PM
It worked for me, but I am using MS XP.
Old 12-04-2003, 11:01 AM
svx_commuter's Avatar
Can you lock the cells with calculations? That way one could not type in where you have calcs.
How about adding the SVX speed, mph and rpm of the wheel?
If your really good, how much the speedo will be off
How about another line underneath the one you got?
Then I could compare the stock tire to the proposed tire.
How about a little write up on the calcualtion method?
Diagram showing the dimension?
The max size of the tire OD that will fit the stock SVX?
Smallest rim ID that will fit the SVX?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 12-04-2003, 01:18 PM
lee lee is offline
PC - WinXP Pro, IE
If it only works for people with Win XP, then that sucks and I need to approach it another way.
svx_commuter, yes the math is simple stuff and I could lock cells, but see above. If I do go another route, I'll try to add in the stuff you suggested. I'll probably have to post it on my own web page as I don't think I know enough to make a stand-alone html file without the help of some package, i.e., frontpage, etc.
Kevin, agree draining and physically checking the pan is the proper way, but I think I change ATF fluid more often than most...Like at every oil change. I'm not yet ready to make the investment of a pan gasket etc at every oil change. Thought it would be handy to know what percentage of clean fluid was in the box. After two changes it's worthless to me, but once I had the column going....
thanks to all who tried it for helping.
Old 12-04-2003, 01:23 PM
Wiz Wiz is offline
Send a message via ICQ to Wiz Send a message via AIM to Wiz Send a message via Yahoo to Wiz
No go on Windows 2000 with the Firebird web browser.
Green 1994 SVX LSi - Totaled by a plow. RIP
Bordeaux Pearl 1994 SVX LSi - 182k
Old 12-04-2003, 05:24 PM
lee lee is offline
OK, can I get someone to try this
I made an html file on my personal web page. Please give this a try and let me know....tia
go to:
http://home.cfl.rr.com/lbridges/
click on the SVX, then on the following page click on the Misc Tools (below the mail box).
I'm hoping this will work for anyone (but it does need Java ). I can't figure out how to do math in html.
EDIT: BTW, I think I have the tire calculator on the personal pages here fixed for all to use, PC, Mac, whatever (but with Java enabled...see above).
