How well does this fit in with the MEP theory?
http://www.timesonline.co.uk/article...805424,00.html
Andy ------------------------------------------------------------------------------------ If I would be a young man again and had to decide how to make my living, I would not try to become a scientist or scholar or teacher. I would rather choose to be a plumber or a peddler in the hope to find that modest degree of independence still available under present circumstances. -- Albert Einstein, The Reporter, November 18 1954 |
So here MEP = 360/(3.25*7.9) = 14.0 That's right in line with the maximum MEP values from other highly tuned NA motors. It beats the SVX by 8.5% and the 350Z motor by 6%.
I am starting to get this now. the Rover k1.8 is pretty impressive then.
230bhp@8600 from 1.8ltrs = 14.857 I take it that this theory doesn't apply to rotary engines (RX8) 231bhp@8200 from 1.3ltrs = 21.67
Re: Re: So the question is...
- Rob |
231 / (8.2x3.9)= 7.2 Hrm. Well, I guess it doesn't apply to Rotaries.... but...eh... anyway, the displacement isn't 1.3 liters. - Rob |
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 10-07-2003 at 02:54 PM. |
Re: Re: Re: So the question is...
http://www.r500owners.com/specnon.html
You're making assumptions about the tuning of the motor that have no basis in reality. Here's one for you... you can take an otherwise stock SVX to over 250hp just with FUEL and TIMING controls. With cams, 11:1 compression, upgraded ignition controls, upgraded valvetrain, and a standalone engine management system, 300hp with a huge stable torque curve is a walk in the park. If tuned properly you could probably see 300hp on pump gas without upgrading the internals. |
Re: Re: Re: Re: So the question is...
I'm game...so what do you suggest as the first steps to get to 250hp (i.e. specific recommendations as to fuel and timing controls)? I've got a legit 4 wheel dyno just up the road (alteredatmosphere), and they do offer on-dyno tuning. -Bill p.s. taking this the next step, what are your specific recommendations re; cams, upgraded valvetrain and standalone engine management system (why do I think this will be the step that breaks the bank? )
- Ca$h |
Using the MEP theory.... to make 300hp out of 3.3 liters with a redline of 6500 rpm would require it to have a mep of 13.98, which is almost 14. McLaren F1 - 13.70 Honda S2000 - 13.33 Suzuki GSX-R600 - 13.22 So you'd have to beat the McLaren F1. Yeah right. However, if the engine could handle...say.... 7.5k (upgraded internals, or a fresh rebuild), then if it made 300hp the mep would only be 12.1, which I think is doable...... - Rob |
#28
Ok, two things... with a piggyback (i.e. Unichip) or standalone (i.e. MoTeC, Haltec, Electromotive) ECU, a whole raft of options are opened up with regard to redline, soft rev limit, and high energy direct coil systems in the case of the standalone units.
The stock valvetrain is spec'd to well over 7k rpm, I see no problem with running it out to that. Our overseas members, please chime in and let us know where your stock redline is and when fuel cut kicks in, I believe it is slightly higher than the US version. Regardless, my target would be something closer to 8.5k rpm. Personally, considering the goals, I would start by upgrading the valvetrain with lightweight valves and stronger springs. It really depends on whether you were going to build it up all at once or in stages. If I was building it in stages I would start with exhaust, and removal of the stock air box intake. Next the EGR system would come off, and while I had it apart I'd have the heads blueprinted, ported, and polished. The intake manifold would also be ported and polished to match. Personally at this stage I'd also have the car stripped and the chassis seam welded, but that's just my preference. I would probably also lighten the body and install a full roll cage tying the front and rear strut towers together. After the prep work is done, engine management and upgraded fuel delivery is in order. A parallel fuel rail would be a necessity, along with larger injectors and a baffled fuel cell. Upgraded ignition controls would be included with the ECU if going the proper route, i.e. a standalone system like the Electromotive TEC-III. So: build the heads and valvetrain, port and polish everything, free up the intake and exhaust tracts, ensure controlled fuel and spark delivery, and take control of the system with a proper standalone engine management system. The tuning is worth probably a third of the total gain by itself once the other pieces are in place, i.e. well over 30hp... higher than that in the right system. It's probably a $7-10k project start to finish. Last edited by Porter; 10-08-2003 at 06:08 AM. |
#29
Wouldnt you have to worry about the rpm limits of the accessories like the alternator, PS pump etc? I would imagine they're not rated much higher than redline.
Mike |
#30
comparison
Just for comparison sakes. We got just over 800 horse (dyno proven) out of our 380 cubic inch race motor. It is a cheverolet design. Its N.A. and fueled by a highly tuned 850 race carburator. All aluminum, brodix block and cylinder heads (18*, sb2.2 stuff is not apicable to dirt because the torque curve is too eradic). Its honda journaled 36 lb crank shaft (gundrilled, $3500) and we run it in the 8800-9000 rpm range. You can have all this, it only cost $30,000. In our buisness you either have it or get beat by it. Motor builder is
Pro Power out of Sulivan, Wisconsin. |
