Old 04-18-2003, 02:41 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Paint codes
I really, really need to repaint the center caps on my '92's wheels (SVXess's put me over the edge ). Does anyone have the correct paint code so the caps match the rest of the wheel?
Also -- am I correct in assuming that there were two versions of "black" in '92? My "black" is definitely different from Immortal Suby's "black" -- is there a regular black and a black mica?.
Anyone have the paint code for black mica?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-19-2003, 09:43 AM
immortal_suby's Avatar
Thread Killah
My black and my wife's black (hers appears similar to yours) are both paint code 235. Mine was banged up about a year after inception according to carfax - I believe it was a total repaint then. I have not seen another black with similar paint yet. It looks almost maroon metallic when it's clean and in the sunlight.
Locker Link
2015 BRZ Limited 6MT
Old 04-19-2003, 10:09 AM
I have seen two different tints of the Black Mica - one with red flecks and one with green flecks.
This was taken from a past thread - I think it was from Aredub:
Painting the Center Wheel Caps
For those who need to paint their center caps, I found that Plasti-Kote Import Color paint code “Datsun 5412” matches the 94 silver wheels perfectly.
For the 92 "gray" wheels, the color "Burnished Silver" works well. I was a little upset with the Burnished Silver when I first painted them, because it looked just a little darker than the wheels themselves. Then, when I bought my second 92, it had brand new centers and they look just slightly darker than the wheels, so, I guess I chose the correct color. Both of these colors should be available at Advance Auto or Autozone.
The thing to do is to sand the old caps down to the yellow, or very close. Then, "mist" them with XIM sealer/primer/bonder (available at most hardware stores, Lowes or Home Depot). I say "mist," because if you put a heavy coat on them, they immediately "blister" and the bonder gives you problems.
After you've misted them with the bonder, let them set for a day for a good "cure." Then, paint. I used toilet paper tubes to sit the caps on for easy painting. Spray the caps as directed. If you're adventurous, you can try painting the "Subaru" in the middle black, by thinning some black paint, and using a very small brush or tooth pick to apply the paint, then "tilt" the cap to allow the paint to flow into the letters (I, by the way, was NOT adventurous).
My caps have been painted for two years now, with no signs of wear.
Old 04-19-2003, 03:46 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Here is a post with codes from the Yahoo message archives. I've read posts from early members who said that body shops, who have had to mix the paint, have a difficult time making it look right. PDsides (I believe) had to have a full re-spray done after a fellow made his car look "dark maroon."
http://www.subaru-svx.net/archive/ar...?message=40232
Randy Johnson
Mike Davis -- at Reading VI
Old 04-19-2003, 08:56 PM
SVXRide's Avatar
Talking Thanks!
Given that all four of my center caps are showing yellow, guess I won't have much to sand
Thanks much for the info!!
-Bill
Old 04-19-2003, 10:00 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Smile
There's also a Plasti-Cote GM silver that's real close. I did mine prior to the Lafayette trip last summer, & they still look good.
Ron.
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
Old 06-22-2003, 12:43 PM
Thread Killah
I found out why my paint is different - it is not svx paint. Gotsubarus father had the same paint on his legacy - it is an ebony mica legacy color. I can't remember the code, I'm sure he'll know what it is. I'm definitely staying with it if I ever get another paint job.
Locker Link
Old 06-22-2003, 09:13 PM
SVXRide's Avatar
Hey, please see if you can get the code -- I'm probably looking at a total paint job next year
-Bill
Old 06-22-2003, 10:05 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Re: Thanks!
-Bill
If you use lacquer thinner you won't have to sand the paint off at all.
Old 06-23-2003, 07:16 AM
SVXRide's Avatar
Re: Re: Thanks!
Nubs,
Thanks, I hadn't thought about lacquer thinner.....now to get the caps off...
-Bill
