Old 03-22-2003, 07:00 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Question Dexron type for PS
Hey all, I just replaced my power steering o ring and I just realized that the subaru manual says to use dexron 2 atf but I used dexron 3. Am I going to damage my PS pump? Should I siphon it out before its too late and replace it back with dexron 2?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-22-2003, 07:14 PM
Green1995SVX
Nah... dextron III is jsut a new improved dextron II. You're all good.
Mike
Old 03-22-2003, 07:16 PM
Bobb Bobb is offline
PS fluid
Hey Te, Dextron 3 has replaced Dextron 2 and it is backwards compatible. BOBB
Old 03-22-2003, 07:17 PM
Tim's Avatar
Tim Tim is offline
Whew, Thanks. I got worried after going through all that work replacing my o-ring. That would have wrecked my day if they werent backwards compatible lol.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-23-2003, 06:59 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
PS fluid
Subaru actually sells their own ps fluid. Its not that much more that ATF and I was told once that it'll make everything last longer in there (I'm sure its not 100% true but....)... Otherwise Dex 3 is just a newer version of 2 and will do the job fine. I actually think that its formulated for higher temps then 2 (kinda like brake flut DOT #s.
