Stop Lamp Warning Light
The stop lamp warning light has been coming on sometimes when the brake is applied. I checked the bulbs and the bulbs are fine, at the time the warning light was not on. ???
Re: Stop Lamp Warning Light
BTW commuter, if this is the problem, check your flexible brake pipes. One of mine had a weeping leak which caused the low level. Joe
Joe this is the other "brake lamp" light not the "brake" light. I never saw this one before it came on. It comes on when a stop bulb burns out.
Doug
Supposedly the "stop Lamp" comes on when you burn out 1 bulb and stays lit. However, if you burn out a second bulb, tha "Stop Lamp" goes out.
Another common problem is the stop lamp checker relay. This is located in theright side in the trunk, behind the panel, in front of the washer fluid reservoir. The design is such that if moisture gets into this area the checker relay acts as a reservoir to collect and hold water. This was my problem. Check the bulbs first. The relay is a simple 1 plug/1 screw operation. Cost of the part is about $38.00.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member 2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I can do a perm. fix for you. Send me your current lights at the back with 500 bucks. I will put LEDs in them. Not the cheap 15 bucks with 5 LEDs either.
L
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
$500?! That stop lamp better be bright enough to guide ships into the harbor on a foggy night! ;-)
KuoH |
stop light bulbs.
The stop light warning system measures the amount of current that flows to the stop light bulbs. As the bulbs age the filament erodes away, this raises the resistance so less current flows. Try renewing the bulbs.
These things are bright enought to light up a cityblock. And I kid you not. L
Thread Tools | |
Display Modes | |
