Old 12-20-2002, 04:07 PM
DavieGravy DavieGravy is offline
Can anything be done to deter rattles
Even with the slightest bump, crap everwhere rattles. When accelerating hard, the force causes the dash creak. It doensn't come from one spot, rather everywhere (dash, seats, doors, etc) The hard suspension doesn't help.
Can things be tightened up? Is there some means to fix this?
Someone mentioned earlier that the rear deck and door locks are prone, but I don't think those are an issue in my case.
Old 12-20-2002, 08:07 PM
CopsodyX
Re: Can anything be done to deter rattles
Was yours ever in a crash? Cause mine has 105k miles, and is 13 years old, and doesn't have even one rattle.
Also, hard suspension??? Not in mine...mine is just a bit firmer than my moms A6.
Actually, my dash does creak for the first 5 minutes after i turn the heat on...it needs the TSB update.
Try to find out about if your car was ever in a crash.
Old 12-20-2002, 09:00 PM
svxy's Avatar
svxy svxy is offline
I stopped some squeekin' by taking the door panels off and tightening all the little screws on the inside of the panels...it helped.
96 Red SVX 96,000 miles
02 Toyota Highlander
02 Nissan Altima
04 VW Beetle GLS
Old 12-20-2002, 09:16 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
If it is body parts rubbing, you may be able to reduce the squeeks with silicone spray, depending on how big an issue it is.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 12-20-2002, 10:12 PM
My dash and lots of other interior parts were taken out then put back in. It was necessary to repair damage resulting from a stereo theft. I saw the interior of my car while being repaired at the dealership. The mechanic took out alot of stuff.
As this occurred over a year ago, I think it's a bit late to go back and say "you guys screwed up." Assumming this is the reason.
The thing is, is I usually have my stereo cranked, thus haven't noticed it as much as the average person would have.
Originally posted by svxy
I stopped some sqeakin by taking the door panels off and tightening all the little screws on the inside of the panels...it helped.
This sound like a good idea, and perhaps, replacing broken brakets.
I'm sorry but I'm not familiar with silicon spray. Where would I spray it?
Old 12-21-2002, 01:44 AM
CDG's Avatar
CDG CDG is offline
If there are body parts that are rubbing against other body parts, they can squeek.
It's a crude method, but it can some times help.
i.e. plastic grommets that join components like door skins, where plastic meets plastic, etc.
Chris G
Old 12-21-2002, 09:19 AM
$VX
The only option I see is to take it apart and reassemble it with foam or something between the dash and whatever it rests on.
I'm going to be doing that this spring.
- Ca$h
Old 12-21-2002, 10:50 AM
CDG's Avatar
CDG CDG is offline
If you take it all apart, spray the plastic parts that can't be foam'd with silicon spray. the same stuff you use to waterproof shoes.
Chris G
Old 12-22-2002, 01:36 AM
- Ca$h
Am I correct in assumming that you've got rattles aswell?
Is this a normal thing?
Old 12-22-2002, 10:47 AM
CDG's Avatar
CDG CDG is offline
I don't have an SVX yet, but I have had rattles a squeeks in numerous cars.
The silicon spray does help rattle, it only helps plastic against plastic squeeks.
The silicon spray removes the friction between plastic parts, and its not corosive of dangerous. and its easy.
But I agree that taking the car apart is the best way to resolve the rattles.
But can be frustrating if you dis-assemble and re-assemble and the rattles are still there.
My experiences have been rattles in doors, dashboards, and sunroofs, in other than SVX's.
So take my advise with a grain of salt.
Squeeks can be fixed with silicon spray without taking anything apart...if your lucky. It a quick fix, and usually last a while.
Chris G
Old 12-22-2002, 04:53 PM
$VX
Well, it is a 11 year old car, and it has a 139,970 miles on it, so yeah, it has rattles. Nothing to obscene, and nothing REMOTELY like my neon (rattlebox), but yeah, it has a few. The most annoying one is from the drivers side door, it happens when I'm playing music at just the right frequency, its the door panel vibrating against the frame. I'm going to fix that when I install my stereo this spring.
- Ca$h
Old 12-22-2002, 05:07 PM
drivemusicnow's Avatar
Poor College Racer
I have squeeks too . I've noticed that it comes from the cd cover, the cigarette lighter and doors. The dash and pillars seem to do creak when the car is warming up. anything you can do about that creakage??
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-22-2002, 10:15 PM
CDG's Avatar
CDG CDG is offline
Oh Oh Oh, I know
wait till the the car heats up, or
Silicon spray, its like duct tape. works on everything.
Chris G
Old 12-23-2002, 04:37 AM
LarryIII LarryIII is offline
On early SVXes (92 & 93) there was some kind of TSB where they removed the dash and put some kind of foam rubber blocks under it to stop the creaking and squeeks.
Good Luck.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 12-23-2002, 11:19 AM
$VX
Mine already had that done but it still happens sometimes.
- Ca$h
