Old 03-02-2021, 02:00 PM
austynn2001 austynn2001 is offline
Pinout for engine plugs?
Hey guys, I'm finally working on getting the SVX harness to merge to the 91 Legacy harness for my upcoming swap. I've got a wire that I apparently pulled out of one of the engine harness side plugs (I'm pretty sure it's the big round one) and I cannot find a picture of those plugs to save my life. Anyone here have one somewhere? Thanks!
Old 03-03-2021, 01:47 PM
Re: Pinout for engine plugs?
there's a picture of it. I've got a black and (yellow I think) wire that is loose and I think goes in one of those two spots. Can anyone tell me which wires reside in those locations please and thank you?
Old 03-03-2021, 06:52 PM
My scanner is off so I have taken a pic of the wiring diagram, you will have t work out which side of,the plug you are look at. The plug is B6. It looks like it is the knock sensor and the shielding.
Old 03-04-2021, 01:41 AM
Sweet! Thank you much! That should help me get squared away. Too bad all the FSM links are dead these days. I guess I should have downloaded them the last time I logged in to this site.. 10 years ago lol
Old 03-04-2021, 03:23 AM
Actually, I've got to see the wires coming from the ECU to pins 12 and 13 of the B6 connector. Those pictures you gave me are, however, very helpful in verifying what I'm looking at. Thanks again!
Old 03-04-2021, 03:32 PM
Yes I looked for 12/13 too could not see them, I'll have another look and post it if I can find them.
Old 03-04-2021, 04:51 PM
Hmm, how about if I told you that it was the black and yellow starter signal wire from pin 10 of the second smallest yellow ECU plug? There's a good possibility I'm completely wrong and it doesn't go to that round plug at all lol
Old 03-04-2021, 05:07 PM
Mate sorry but, there is no 12/13 listed in my Australian FSM.
The US car does have another unit that we don’t have, that is a temp sensor for the EGR system that is on the inlet manifolds EGR line that tells if hot gas is flowing when the EGR is working, the Aus car does not have it, so that could be what 12/13 are used for.
Old 03-04-2021, 05:22 PM
The starter does send a signal to the ECU via the Cruise control, to tell if the starter is working, also to tell the ECU to go to the start system.
As far as I can see it comes from the inhibitor switch circuitry not plug B6.
Old 03-04-2021, 08:26 PM
"13" (Yellow/Green in and out) involves a circuit sensing temperature and "12" (Yellow/Back) the oil pressure sensing switch. Both circuits are completed via a ground connection.
The oil pressure switch completes a circuit to the oil pressure warning light and therefore should be normally open. You can verify the circuit by shorting socket wire "12" to ground and observing the warning light with the ignition on.
You will probably be able to measure some resistance between plug wire "13" and ground and shorting the socket wire to ground should move the gauge.
Old 03-05-2021, 05:40 AM
Ok, maybe I pulled the wire from a different plug. Can anyone tell me which plug the black and yellow wire goes to when it leaves the ECU connector?
Old 03-05-2021, 08:59 AM
irox irox is offline
Here's the wiring diagram section:
https://cardiagn.com/1992-96-subaru-...oubleshooting/
Full (I think, I didn't check each volume for completeness) manual set:
https://cardiagn.com/1992-1996-subar...iring-diagram/
Old 03-07-2021, 05:13 AM
Hell yeah, thanks man! That should do the trick.
