Old 12-28-2014, 10:26 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Question about adjusting AMR coilovers
The height in the front looks too high to me so I wanted to lower them.
The fronts measure (from outside the wheel) 26" from the ground to the lip of the fender on the front. The rears are only 24"
Can anyone tell me which of the collars you adjust on the coilovers to change the ride height? I thought it would be the one that meets the spring but after tinkering with it I am not sure. I lowered the spring collar down to about 1" left on the thread and it only lowered the car 1/2"
Once I loosened the collar that much, the spring I noticed that the spring was loose at that point. Once I put the wheel back on and lowered it the spring went back into place and is snug again but something about this doesn't seem right.
Should I be adjusting the lower collar instead? I tried that at first but it was so stiff I couldn't move it (even with no weight on it).
Any suggestions would be appreciated. Thanks!
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 12-28-2014, 12:32 PM
Re: Question about adjusting AMR coilovers
Generally speaking coil over height adjustment is done by threading the tube itself up or down through the flange that attaches to the knuckle. The nuts under the spring only adjust preload which can change ride height but is not a good way to compensate. I have not seen the specific ones you are talking about though. Perhaps a picture?
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 12-29-2014, 04:27 AM
halistan's Avatar
Grand Poo-Bah
I think I have it figured out now. However, to loosen the lower collar, I need to be able to move the bracket that the sway bar is attached to and I can't seem to get it off. When I give it another try, i'll take a picture to show.
Tags
adjustment, amr, coilovers
