Old 11-25-2014, 02:59 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Smile 94 Green LS - FWD partout
I have a 94 that I'm parting. Parts I have that need to go include the following. I will add more in the coming days. Thanks! Marc
  • FWD Transmission
  • Both L & R rear door glass (Bronze)
  • Window regulators & Motors
  • ABS sensors
  • Rack & Pinion (Complete)
  • Brake calipers, front and rear
  • Y pipe exhaust components (resonators & cat)
  • Caps galore
  • Electrical components galore
  • Steering column with turn signal switch
  • Airbags (Beige - Drivers and passengers side)
  • Complete, uncut, Main wiring harness (inside cabin, under dash)
  • low side AC hose
  • high side power steering hose
Old 11-26-2014, 09:28 AM
theflystyle's Avatar
Re: 94 Green LS - FWD partout
PM Sent...
1994 SVX LSi
2008 Legacy 3.0R
Old 11-30-2014, 10:33 AM
svxcuseme's Avatar
5 speed 4 sure
Replied with prices
Old 12-10-2014, 12:03 PM
svxcuseme's Avatar
5 speed 4 sure
List updated with a couple more items...
I have a 94 that I'm parting. Parts I have that need to go include the following. Thanks!! Marc
-Beige Carpet
-FWD Transmission
-Both L & R rear door glass (Bronze)
-Rear window regulators & Motors (1 front passenger side regulator and motor)
-ABS sensors
-Rack & Pinion (Complete)
-Brake calipers, front and rear
-Y pipe exhaust components (resonators & cat)
-Caps galore
-Electrical components galore
-Steering column with turn signal switch
-Airbags (Beige - Drivers and passengers side)
-Complete, uncut, Main wiring harness (inside cabin, under dash)
-low side AC hose
-high side power steering hose
Thanks!!
Old 06-19-2015, 04:49 PM
rrhenderson's Avatar
rrhenderson rrhenderson is offline
MacArthur
Hi. Sent PM for Front Passenger Window Motor. Oops, I should have written, "Do you have Front Passenger Window Switch (instead of Motor)? Thank you.Thanks.
Old 06-21-2015, 09:08 AM
epesposito epesposito is offline
Looking for usable crank sensor for 1997.
thanks
Tags
exhaust, pinion, rack, regulator, transmission
Display Modes Rate This Thread
Rate This Thread:
