Old 07-01-2014, 07:03 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Hick-up
Has anyone's SVX had a hickup while driving? While driving along at 45 to 65 mph the engin just stops for a half second (maybe less) then picks back up running strong. This happened once on the dragon Saturday, then three times yesterday on the way home. I first thought it was just shifting or something, but yesterday I was just running along smooth and straight when it did it.
Could be a coil, but when one of my coils died last year you could tell it was missing, so I replaced it. This new problem is intermittent, any ideas?
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 07-01-2014, 07:07 PM
Re: Hick-up
I'm thinking MAF sensor starting to fail.
If it is, most likely it can be repaired by re-soldering the connections inside. There's a how-to on here somewhere.
Old 07-02-2014, 02:57 AM
Re: Hick-up
Exactly what is happening to mine.
Old 07-02-2014, 03:12 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Hick-up
Spark plug leads - where thay attach to firewall ---- took my mechanic a long time to find it ...... breakdown where lead clips into the black block on firewall (forget what it is called sorry).
Old 07-02-2014, 09:51 AM
SomethingElse's Avatar
word words wording
Re: Hick-up
Are you talking about the ignition module or the actual spark plug connectors?
The solder breaks on those pins too?
Eric
Old 07-05-2014, 05:37 PM
SURTEESS's Avatar
Re: Hick-up
it was the lead - the front spart plugs (here in NZ) are made up of 2 separate leads (joined end to end) - one had a split cover that was shorting to block.
