No start problem OUTBACK
Just got a 1999 limited 30th anni. outback and it won't start. Put a new battery in it and as soon as I turn to start it the clock goes dim and nothing happens. I jumped the starter from the battery and all it does is crank but wont attempt to start. Main concern is why wont the key kick the starter on, I hear the solenoid clicking when I turn it but it just won't go. I'm getting fuel and spark. Any ideas?
Re: No start problem OUTBACK
Have you checked the Alternator?
1995 POLO LSI 76K MILES SOLD |
NEW alternator
You obviously have power to the solenoid. Hook the clamp end of your test light to an engine ground then touch the test light to the starter post with the switch in start position. If you get no response to your test light the solenoid contacts are bad. If you get the test light to light you have problems with the starter.
The starters good also. Im just not getting any power to the little connector that goes on the starter.
Auto? Check the connector to the shift indicator, it can be together enough to seem to work, but not enough to pass enough current to the starter.
Manual? Check the clutch switch.
Thread Tools | |
Display Modes | Rate This Thread |
