Old 08-19-2012, 01:45 PM
NSTG8R's Avatar
NSTG8R NSTG8R is offline
Airplane builder-upper
DAAAMMNN!! That was scary!!
If it's not one thing, it's another on the car. I just got it back from the muffler shop ($600) with a manifold back, Magnaflow exhaust...sounds a little "ricy", but I don't mind. Found a back road to open it up a little and see how she's running....very nice! Had to hammer the brakes for an upcoming curve (90 deg), pedal goes to the floor!!! Parking braking and drifting through it, THANK GOD no one was coming the other direction. Got it home and found the hard line on the left rear brake blew, looks like corrosion did it in. So I ordered all the brake lines, front, center and rear, and a set of SS lines to the calipers. Has anyone replaced 'all' of the brake lines before? It's looking like it's going to be an absolute nightmare.
He who hesitates is not only lost, but miles from the next exit.
Old 08-19-2012, 02:33 PM
smc smc is offline
Re: DAAAMMNN!! That was scary!!
Good gawds, man! Just reading that made my heart jump! Im glad your alright
Old 08-19-2012, 04:23 PM
NSTG8R's Avatar
Still pulling seat leather out of my a$$!
I imagine I'm going to have to pull the whole rear end out, and half the engine compartment to replace them, put I've kind of lost faith in the 20 year old "flight critical" [I build airplanes] equipment on this car. Glad it didn't happen on one of my "$hit, running late, haul a$$ to work days".
Old 08-19-2012, 06:07 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
My rear brake lines recently bit the dust (not as bad as yours), but I was able to rerout the new lines around the gas tank. Took the shop only a little over an hour, and now they're totally accessible for and future repairs. Doesn't really help your whole issue, but it'll save those 6 hours to take the rear end apart!
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 08-19-2012, 07:46 PM
NSTG8R's Avatar
Yeah, I guess stuff like this is to be expected with a 20 yr. old car, especially in the midwest. I already ordered the lines, but what you did sounds like a good idea. And for any members that haven't taken a look under there for iffy looking components in awhile, I'd HIGHLY recommend it.
Old 08-19-2012, 08:00 PM
B 4 You's Avatar
#lolsvx
The lines are flexible aren't they? To an extent at least. The shop COVERED them in undercoat stuff too, just to make them even more secure. They debated doing it that way with my fuel lines, but they said it's not as smart with fuel to be exposed like that. They cut the brake lines as soon as they go into the back seat, and put all new ones all the way to the rubber ones to the calipers.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 08-19-2012, 09:53 PM
I'm dealing with the same thing for a local customer's SVX. Only 75k miles and relatively rust free. I took it for a drive the other day and had to do a hard stop for a light changing to red and the pedal went to the floor. Luckily was able to stop and limped it back using the transmission to engine brake as well as the handbrake. Using the service brakes only enough to signal the brake lights.
Old 08-20-2012, 12:09 PM
Austin Austin is offline
Holy poo!
This is not encouraging. I'm currently down with an assortment of fixable problems, but the one that's really got me stumped is a brake leak somewhere. When I am able to drive it, I have to refill my resevoir about every other day or so, and that's with me driving in ways to minimize using the brake pedal.
Thing is, I can't track down the leak - there's not a drop on the driveway. There's none around the master cylinder where it connects to the brake booster. There's none on the firewall inside or out.
I saw on here once that the lines run in the rocker panel, but I don't see any access holes under the plastic trim. I know that at some point they're exposed under the back seat, but like I said, there's no pooling of fluid anywhere. Although it's sidelined now with tranny issues and I can't drive it, when I was driving it I had gone through several quarts (maybe a couple of GALLONS!) in the last few hundred miles (or less?). So the fluid's got to be pooling somewhere... eating my paint, etc.
Hearing these brake line stories scares me.
Oddly, I've owned 4 XT6es and never EVER had brake line issues with any of them. In fact I don't recall even hearing about brake line issues with an XT6 from any of my fellow owners. WTF, Subaru?!
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
Old 08-20-2012, 04:38 PM
NSTG8R's Avatar
Actually, once I got it home, it was dark. The next morning I figure (read:hoped) that I'd see that one of the calipers had let loose...no such luck, all wheels bone dry, nothing on the ground. Popped the hood, 1/4" of brake fluid left in the resevoir...has to be somewhere . It wasn't until I started bleeding the brakes (one man vacuum thingy) that it reared it's ugly head. Just to the right of the rear diff, and directly above the fuel inlet tube. Tons of undercoat still didn't protect it, and I'm not taking anymore chances...new stuff on the way. I've got 3 '70's Porsche 914's, and the reason I bought a SVX in the first place was to jerk the engine, and drop one in my '73. Got to liking the SVX and didn't have the heart to do it (got an extra engine for that ). I just know, just like the 914's, as soon as I tear into it I'll find more and more stuff that needs replaced. Not looking forward to this at all.
Old 08-22-2012, 12:21 AM
smc smc is offline
Time to get your svx man rated again and back on the tarmac!
Old 08-23-2012, 07:38 PM
NSTG8R's Avatar
Agreed! Got my SS braided lines from Planet SVX (plus a TCU and Stage I from ECUtune), but going to custom make the hard lines. They definitely won't be going the original routing. Tearing into it this weekend.
Old 08-23-2012, 09:48 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Good luck with the project and some pics will be nice,too
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 08-28-2012, 08:17 PM
NSTG8R's Avatar
Going to have Isaac rolling up here this weekend, so I'm going to limp it up to a buddy's garage, and get started on it Tues. (next Tues. that is). Doing the ECUtune TCU and Stage one while I'm at it. I'm no photog, but I'll try to get some pics of the new install, and definitely one of the "Watch out for this section of brake line! " for fellow owners.
Old 08-29-2012, 07:18 AM
SVX_MY_BABY's Avatar
Originally Posted by Austin View Post
Holy poo!
Could well be where they go over the gas tank.
Peter
Old 08-29-2012, 04:15 PM
sabin sabin is offline
Banned
Same thing happened to mine, leak was up under the subframe
