losing oil..
the car is dripping oil from somewhere, it has been doing this for years and i once went to a mechanic who told me he would have to open the (box that holds the belts) because it seems the oil is leaking from there somewhere, he told me it would cost over 1000 because he would change the belts too to make sure they dont break... didnt help much, i never did anything about it, and add a little oil every 3 weeks depending on how much i burn... when i put the pedal down and drive it agresively, you can smell more oil driping on the exhaust which causes a burning smell... besides that the car runs good though and i have 240,000 miles on it.. any ideas as to what oil leak could be..?
Re: losing oil..
My bet is on leaking valve cover gaskets; a common problem with the SVX. could just be loose and need to be tightened a bit.
Replacing them is not a complicated job, just time-consuming. Might as well change your plugs at the same time. The How-To can be found HERE. It can be done without removing the engine. When was the last major maintenence done? (timing belt, water pump, plugs, etc.) .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-05-2011 at 07:35 PM. |
Re: losing oil..
i agree that it sounds like the vc gasket because the front cam seals (which are behind the cover) don't usually end up on the exhaust. you may be able to just tighten down the bolts to stop the leak. ti also sounds like your mechanic might not know much about the svx or is greedy because over 1000 bucks to replace the timing belt and possibly a couple seals is really steep.
Re: losing oil..
My bet would be all seals need replacing. While doing the front seals, a water pump, thermostat, and timing belt parts are a good idea. If you want someone who knows what they're doing and won't rape you on pricing, send me a PM.
I'd also be willing to put money on the table that the PCV valve could use replacing. |
Thread Tools | |
Display Modes | |
