Old 08-22-2011, 02:14 PM
waltweems waltweems is offline
Angry 92 power steering - desparite for help
92 LSL PS problem. no assist when car is stopped. Steering wheel jerks back and forth. In motion it's OK. I've replaced the rack with a rebuilt one from a national rebuilder of racks. Had the pump rebuilt. Bought a new control valve
and a new check valve. The pressure at idle is 150 and at high RPM is 800+. I have not replaced the hoses.
I don't know what else to do and would greatly appreciate any thoughts.
Thanks
Walt Weems
Old 08-22-2011, 02:28 PM
Re: 92 power steering - desparite for help
Does it get better after being driven for a bit to get the air out of the system?
If air remains in the system, double-check the o-ring between the pump and the reservoir.
Old 08-22-2011, 04:18 PM
check the connection at your power steering pressure switch, i had this intermittently for a while and it turned out to be the switch that raises the idle when power steering is needed. i guess the switch was ok but the connection was bad.
Old 08-22-2011, 11:54 PM
I would put money on the O-Ring!
Old 08-23-2011, 04:59 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
'desparite' ?????
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 08-23-2011, 11:34 AM
Question Re: 92 power steering - desparite for help
Thanks for the tips. I will take the reservoir off and check the seal. I have rotated the steering wheel left to right and back at least 20 times to bleed the system. I'm not sure how to tell if air is getting in, but i will be so glad if the
seal is the problem. I have already replaced the switch that comes off of the right side of the pump.
Walt
Old 08-23-2011, 12:59 PM
Moving it back and forth does nothing . You need to crack a line and make it pump fluid out . Unless that is what you are doing.
Old 08-23-2011, 01:52 PM
Crack a line??? Which one? I've always turned the steering wheel left and right on other vehicles.
Walt
Old 08-24-2011, 05:58 AM
Angry Re: 92 power steering - desparite for help
I replaced the O ring between the pump and reservoir but it did not help. I noticed the fluid in the reservoir is foaming.
Anyone know of a good shop in Md, DC or VA.
Walt
Old 08-24-2011, 08:55 AM
When did you last change your power steering belt? I thought mine was good but my steering acted like yours. I replaced the belt and it was perfect.
Old 08-24-2011, 09:05 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
My 94 pearl (with a translplanted 96 drivetrain) did the same thing. Replaced the infamous O-ring and it was good as new.
1995 POLO LSI 76K MILES SOLD
Old 08-24-2011, 09:50 AM
Try shooting some penetrating oil on the knuckle connecting the steering column to the rack... if it frees up... you found the problem
