Old 07-01-2011, 06:47 PM
The Molinator
Brass (double-male) barb connector.. .
Can I use a BRASS double-male barb connector to connect ends of AT fluid lines. Is it compatible with the ATF? I previously hooked two AT lines together (between cooler and campaign filter) with a scrap aluminum tube with lip on one end only .. IT CAME OFF ABOUT 6 MONTHS AGO.. SPILLING ATF EVERYWHERE ON MY WAY HOME FROM WORK! Ha!
Thanks..
Jim
Old 07-01-2011, 07:16 PM
XT6Wagon XT6Wagon is offline
Re: Brass (double-male) barb connector.. .
You should be able to get a good properly barbed connector in aluminum.
Old 07-01-2011, 07:23 PM
The Molinator
So, BRASS is a problem.. with the ATF?
Jim
Old 07-01-2011, 08:08 PM
wawazat??'s Avatar
Yeah, I'm still around
Try an avoid a yellow metal like brass in a system (flow circuit) comprised mainly of aluminum. Steel would be a better choice if you can't find aluminum.
Down to none
Old 07-05-2011, 01:56 PM
The Molinator
OK! Thanks!
Jim
