Water pump froze, stripped timing belt - help
Just happpened last night so this is my best quess. It appears that the Water pump froze and then stripped the teeth on the timing belt, It all turns freely. Here's my biggest fear - Is this pump intergal to either the drive shaft or cam and could I have bent valves?
Thanks, Moggie |
Re: Water pump froze, stripped timing belt - help
Hope it works out well. Keith |
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Thank you two - I will start wrenching. Moggie
I've remove everything - the water pump is out and frozen solid, even a pipe wrench on the spindle does not budge it. I also had tow idle pullys in pieces - berrings every were and one idler pully melted into the cover. The timing belt is shreaded. I did not remove the crank sproket or the cam sprokets.
So, water pump, gasket, thermostat, two ilder pullies - anything else I should do while I'm in there? Moggie |
Front main seal (around crank on the front of the oil pump). Especially if it looks old. Make sure that the crank pulley for the timing belt does not have any play in it. The Keyway should fit snug on the pulley. Same goes for the cam sprockets, but its harder to tell with them since there is a bolt putting tension on them. Other than that you should be good.
MAKE SURE THE MARKS ON THE PULLEYS LINE UP WITH THE MARKS ON THE BELT. There are also marks on the timing covers, but do not follow them. Good luck with the reassembly.
my pump went bad and it cost $200 to get it and the timing belt replaced. I bought the parts.
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS |
Thanks Cam,
They all feel tight - I'll order parts. Moggie |
Why would you not follow the timing cover marks? How else would you line up both cam gears to the TDC correlating position? Just curious...
1 they don't line up properly...2 there are marks on the pulleys for the cams
Thread Tools | |
Display Modes | |
