Old 06-30-2010, 09:29 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Oil gauges.
I have been try to chek out how to innstall a oil-pressure and -temp gauges.
Are the some contak on the engine or must it bee drill a hole in the block to too this.
I have find a extrapart to the oil filter to read this.
Like this one.
but i dont know how this is.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 06-30-2010, 12:30 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Re: Oil gauges.
The oil pressure sender unit on my car is running from the location of the stock Oil Pressure sensor (on top of the engine slightly behind the Alternator). Tom used a T fitting and sensors screw in on the opposite sides. Seems to be the easiest way of doing it, for wiring and for read out purposes since this is the spot the stock oil pressure sensor is located in.
Old 06-30-2010, 10:34 PM
Alex-svx's Avatar
Re: Oil gauges.
Ok. Thank alot for the answere. Then i have to chek this out.
Alexander (Norway)
My subarus:
Old 07-01-2010, 05:16 AM
Re: Oil gauges.
there are aftermarket galley plugs available as well. this will allow you to use any oil galley plug as a tap for the sensor.
Old 07-02-2010, 06:16 AM
Alex-svx's Avatar
Re: Oil gauges.
Ok. But how are this looking. Have annyone pictures of it.
Alexander (Norway)
My subarus:
Old 07-02-2010, 11:16 AM
Sov13t's Avatar
Re: Oil gauges.
I will be replacing my alternator hopefully this weekend. Will snap a pic or two of my set up.
-Sov13t.
Old 07-02-2010, 01:47 PM
Alex-svx's Avatar
Re: Oil gauges.
-Sov13t.
Thanks that will bee grate.
Alexander (Norway)
My subarus:
Old 07-03-2010, 02:54 PM
Re: Oil gauges.
If yo get a galley plug tapped for the sender it would look something like this
Not sure it would fit under a stock manifold
Old 07-06-2010, 07:51 AM
Sov13t's Avatar
Re: Oil gauges.
And here is a pic of mine:
Old 07-08-2010, 08:03 AM
Alex-svx's Avatar
Re: Oil gauges.
Thanks alot for the Pictures. Its help me alot.
Alexander (Norway)
My subarus:
