Ford Ranger brake problem
Sometimes while coming to a slow stop, the pedal pulsates and goes further down to the floor. It feels almost the same when you have air in the line. I bleed the lines and it didn't change. My rear drum brakes are on it's last leg and I will replace them this week. Would this be the cause for my problem, not having enough pads left? PS It is not the antlock brakes.
Re: Ford Ranger brake problem
How do you know that the pulsations are not caused by the ABS system?
Anyways, pedal going down after a few seconds often means that the main brake cylinder needs repair.
95´ Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe |
Master cylinder broken?
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
I'm a "Ford Guy", so, I may have a few insights for you.
Check your brake fluid. If your back shoes are thin, then your fluid will be low. This won't cause a pulsing pedal, but it WILL cause the master cylinder to suck air. (causing the pedal to sink like you describe) Odds are the pulsing pedal is the front brakes....not to worry, unless it feels like the truck is coming apart at the seams. In that case rotors may be the order of the day. Ford ABS makes a really weird screeching/moaning nose when active. If it were acting up it'd be painfully obvious.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
The answer to your problem is on the tailgate. It should even be circled in blue
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
Thread Tools | |
Display Modes | Rate This Thread |
