I took today off work
The svx needs some work to get her roadworthy, like the timing belt. I started to clean up the bay a little last week and found this little eyesore!
Over the weekend I have been doing a little at a time. My back only allows a couple hours at a time. All of the orange stuff is penetrating oil that sat from some rusty bolts(note to self don't spray stuff at the block you don't intend to wipe away immediately). The mud, sand, dirt, & glass...don't ask, was so deep I practically had to shovel it out of the grooves in the case. Some advise to anyone washing their engines, used some compressed air to thoroughly dry the engine so this stuff doesn't build up. Here is how it stands now, I have a long way to go but I feel progress has been made. Especially without any compressed air or pressurized water. Just elbow grease.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 08-11-2009 at 03:58 PM. |
Re: I took today off work
looks great. I wish I had that kind of time...
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
anyone know where to find a V shaped wire brush for a drill. I still cant get into the crevaces. This corrosion is so hard to get off
http://s26.photobucket.com/albums/c1...l/2c533ea1.jpg
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 05-24-2009 at 06:57 PM. |
well I tried to fix your pic...
Thanks for trying. No copy n paste iphone. I picked up some tiny dremel brass brushes. Hopefully that will do the trick. I'll try to post a pic again.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
You are doing a really excellent job on it Mike.
Same as you I find it truly backbreaking work, staying bent over in the one position for ages. Fair dues to you, you are at least getting some benefit from the backache with a lot of sparkle from that block. The only problem I find with tackling a big clean-up like yours is the fact it tends to escalate; you then go on to clean up the alternator/powersteering/pulleys etc etc. At least it keeps us busy and amused. Joe
I might have mentioned; the above reply is written by someone who spent 4 hours cleaning up his lug-nuts last week!
As far as the back goes, I'm not able to move right now. I just got back from a 3 hour session with the dremel. What a difference that little bugger makes. It got in places I could never reach with the wire brush. I think after another wash I can call the block clean. With finances the way they are this is about all I can afford to do to the SVX.
Todays progress
Now, that really is starting to look TIGHT.
Comin along real nice
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
You should go buy 4 jack stands and a jack, if you don't have one, and jack up your car high enough that you can work on it without bending over, that's what I do when I'm working on something at my shop, since I don't have a lift, I find it a lot easier on my back if I don't have to bend over to work on stuff.
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
Thanks for the tip, I already have them and I'll do just that next time I work on it. Does anyone have knowledge about the factory coating they used on the motor. I heard it's wax based, I also read you can use a variety of other products like WD-40, Corrosion X, Engine Detailing spray and even PAM. I was hoping to use something that will last a long time and not attract dust like wd40 but not permanent like clear coat or paint.
Here is another 3 hours this Saturday, Hydrochloric Acid wash followed by eagle one wadding polish. The polish works wonders, I recommend it for any aluminum parts under the hood.
Nice, Good job.
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
Thread Tools | |
Display Modes | |
