My possessed car - video
srsly, wtf. I just replaced the alternator and battery, dremeled the ground points, continuity is good between battery and chassis, and it's still doing this ****. After it warms up and the rpm's drop it will slowly bog down and die at idle.
No smoke, fluids, or funny noises coming from the engine. I'm selling it tonight to a buddy driving down from Massachusetts and need to know if this could possibly be a quick fix, or something worse. I want to sell it for an honest price so if it's an exploded engine, fine he can take it cheap. Just want to find out what's wrong.
Brian Last edited by Ricochet; 01-09-2009 at 11:44 PM. |
Re: My possessed car - video
Oops ok the vid just loaded..... I rescind my last post lol. Given that it seems random enough and it does it more while the car is vibrating/revving, could be a loose harness or wire? Electrical issues are such a pain in the a$$!!
Chris "A person convinced against their will, is of the same opinion still" New?? Find the downloadable SVX Online Service Manual Here RECOMMENDED READING for newer SVX owners Here some cool info if not fully accurate. Last edited by SoCal LS-L; 01-09-2009 at 02:38 PM. |
Its gotta some related to battery/alternator. How are the connections going to the alternator?
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
I checked everything with an ohm meter, all wires are connected fine. This new alternator came out of a perfectly-running svx.
Brian |
What happens if you measure the volts across the battery when you rev like that? If that's not a charging system or ground problem, I'll be surprised.
Disclaimer: The above post is on the internet. |
With that kind of lighting, I'd almost be inclined to think it had to do with the regulator in the alternator - wavering output with engine speed, regulator could be broken.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
get a mm tester and check the battery voltage. maybe the battery is no good, maybe the alternator is not producing 13.8 volts or higher.
its one or the other, or a bad battery connection.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
please post when you find the source and the solution.
What is the alternator putting out???
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
if the battery is charged up and functioning properly it will run for 30 miles without an alternator.
No lights or accessory on of course. |
my friend and I need to go slightly more than 30 miles to get this car though...
Check the ground on the backside of the manidol passenger side. There should be a 12mm hex head holding it on. Make sure it is a good connection and that it is tight
Tom |
Quote from Ricochet: I just replaced the alternator and battery, dremeled the ground points, continuity is good between battery and chassis, and it's still doing this ****. Sense that doesn't even happen when the battery or alternator is bad, I would suggest maybe looking for a problem other than the alternator and the battery if you have tested them already. Keith |
Took a glance at the fsm and it says to check or replace fan belt, check alternator, check terminals for improper contact if the charge light is on at idle which his is slightly.
Pardon my ignorance, where is the fan belt?
Brian |
Thread Tools | |
Display Modes | |
