Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 04-25-2008, 01:33 PM
The Molinator
Regular Gas- Chip Switch
I installed a computer chip (SmallCar?) about 4 years ago. I never completed installation of the switch that allows the SVX to use Regular Gas Because I was using an effective Gas Pill that helped gas mileage while still using Premium Gas at that time.. .
Last night I just paid $4.14 per gallon premium gas! Does the switch work well? Are many of you using it now? Please give me any info you can ... so I can make an intelligent decision about using that feature.
THANKS! Jim
Jim
Old 04-25-2008, 02:09 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Jim,
that would be the ECUTune chip
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-25-2008, 02:28 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I wish I could buy gas for $4.14 a gallon.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-25-2008, 04:30 PM
etz bseder etz bseder is offline
Yeah, I had the chip in when I had the SVX still. It worked great, no problems. I was getting above 20mpg city in a city that's 5 miles by about 12 miles, so I never got to drive a good distance.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 04-25-2008, 04:56 PM
The Molinator
Switch!......???
Does the REGULAR GASOLINE Switch work? Please give me any info about it...before I use it and find it causes some problem..or is useless! Many in earlier threads spoke that our SVX's work OK with Regular Gasoline without modification. BUT, others said that's not good.
Is this a good mod to use? I already believe the ECUTune 1 is giving my SVX a little pep through the chip maps mod.. .
THANKS! Jim
Jim
Old 04-27-2008, 07:26 AM
Old Fogey
Jim,
Mine has been installed for a year or more but never tested. I just couldn't stand to think about losing the pep the Stage1v4 had given the car. Now, having not filled the car with fuel for over 2 weeks, through the jump past the "mystical" 4 bucks, I guess I'll be testing it next fill-up! Sorry I couldn't give you more info.
Glenn
Old 04-27-2008, 08:34 AM
Manarius's Avatar
Manarius Manarius is offline
Hmm, I run regular gas without a chip....
-Jason
-Obi Wan Kenobi
Old 04-29-2008, 07:21 PM
The Molinator
Anybody Using The Reg Gas Switch?
CAN ANYONE TELL ME WHAT THE REG GAS SWITCH IS SUPPOSED TO DO ON THE EcuTune STAGE 1.v4 chip install?....HOW IT WORKS?...AND IF IT DOES AT ALL..? HELP!
Thanks, Jim
Jim
Old 04-29-2008, 07:40 PM
Thanks, Jim
I guess it just reduces the full throttle spark advance, to suit a lower octain fuel, without it pinging or knocking.
Old 04-29-2008, 07:47 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Read about it here the ECU Tune website.
-Nate
'92 LS-L Pearlie
Old 04-29-2008, 07:56 PM
The Molinator
Thanks.
dat helps.
Jim
Old 04-30-2008, 03:10 PM
immortal_suby's Avatar
Thread Killah
Perhaps if I move this to the ECU Tune forum it will get you the answer you are looking for.
Locker Link
2015 BRZ Limited 6MT
Old 04-30-2008, 07:32 PM
The Molinator
Uh! Oh!...Stupid!....AGAIN!?
I like to Move It!..Move It!
He likes to . . . . ..Move It!
Sure!...Thanks! Jim
Jim
Old 04-30-2008, 07:52 PM
Thread Killah
Sure!...Thanks! Jim
Arghh! now that is in my head.
Locker Link
Old 05-01-2008, 03:43 PM
finleysvx finleysvx is offline
How do I know??
I only recently purchased an SVX and am just finding out what this car is all about. How do I know if the previous owner installed the Stage One chip/switch?? Is there an easy way to find out? Because I do have a slight engine knock and hoping it isn't fatal. Appreciate any info anyone can offer. Thanks
Abe
Display Modes Rate This Thread
Rate This Thread:
