Old 10-29-2007, 11:15 PM
cruisen_15's Avatar
svx sounds diesel
when i listen under the car near the belts and oil pan there is a loud knocking and it almost sounds like its diesel.... is this normal??
Old 10-30-2007, 05:20 AM
wawazat??'s Avatar
Yeah, I'm still around
No its not normal.
Down to none
Old 04-20-2013, 09:50 AM
theflystyle's Avatar
Re: svx sounds diesel
yes i know, an old thread bump....
i was looking to see if anyone else had a svx that sounded like a diesel when it was running. keep in mind this is my first svx but not my first boxer engine (H4 or H6) so i know what they typically sound like. comparing it to the videos on youtube i cant what is causing mine to sound as loud as it does.
here are some of the ones i found to compare
Idle video 1
idle video 2
i plan on taking a video of mine and posting it up here
1994 SVX LSi
2008 Legacy 3.0R
Old 04-20-2013, 01:05 PM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Mine sounds a little dieslish now. Mainly due to neglect, hope it will be creamy smooth again when the engine is pulled and overhauled.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-20-2013, 02:28 PM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
the loud deep thumping is rod bearings that are quite worn from neglect slamming about...
Old 04-20-2013, 05:08 PM
bishop bishop is offline
I agree with Jake that its rod bearings but I also think its an oiling problem because my car only does it sometimes.
Old 04-21-2013, 08:23 AM
PO used mobile one synthetic 5w-30 and I followed with that since ive had the car. i dont recall a difference in the loudness after any changes however
1994 SVX LSi
2008 Legacy 3.0R
Old 04-21-2013, 05:19 PM
The harmonic balancer will make a loud knocking sound if it is not tight.
Old 04-22-2013, 02:13 PM
jetboy's Avatar
I personally don't have anything I would call a rocking sound. Just a bit farm machinery like when I start up.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-26-2013, 12:42 PM
As promised, albeit a little late, the a video clip of my sound.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-26-2013, 01:48 PM
wow, that is much different than i imagined. Im torn though because something on that engine is messed up but at the same time diesel rumble is kinda cool.
Pull the timing covers, i wonder if theres a pulley in there thats going bad and rubbing something.
Old 04-26-2013, 03:12 PM
i would take a nice purr over that noise. the driver side timing cover is already somewhat cracked at the screw so who knows what it looks like back there.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-30-2013, 12:27 PM
Tapani Tapani is offline
I just tried to listen very carefully mine. With an engineers stethoscope and w/o. Then did the same for the 2006 3.0R Outback. What a difference.
The 3.0R is silky smooth - there's not much anything but a constant whizz even with the stethoscope.... by far the loudest part is the power steering pump.
The EG33 sounds "harsh", not "wrong" to the ear - I can hear the individual injectors tick and some general rumble. With the stethoscope there's a whole cacophony of mechanical clicketi-clack... slight in the head castings, some more from the block... by far the loudest at the cylinder #6 (drivers side, rear) - right where the piston/cylinder is - a bit less at the block split joint. Very, very different from the EZ30R.
I need to replace my head gaskets and I am trying to decide whether to do the rod bearings while engine is out. Removing the pistons is a PITA and splitting the casings does expand the project quite a bit. 130kmiles, 5PSI turbo charged.
I have ever heard only one other SVX engine running and it did appear to run smoother on idle. Didn't pay much attention, though.
theflystyle: There are two different type sounds in yours... like a diesel injector/combustion sound - and then a single much lower knock - big end, burned valve?
Did you have your AC compressor running in the video?
Hmmm.....
Tapani
Old 04-30-2013, 05:17 PM
^ I fully agree with your comparison to the 3.0R. Night and day difference, sometimes I cant even tell its running at idle.
I did not have the AC running in the video, and that was after a 30 minute drive so the car was nice and warm. I am still getting some small drips of oil even after changing the valve covers. The headgasket was also recently changed and is not dripping as well. Its coming from further back
1994 SVX LSi
2008 Legacy 3.0R
Old 04-25-2019, 03:55 PM
Huskymaniac's Avatar
Uses the ignore feature
Mine sounds like that too after the headgaskets job. What did it turn out to be?
Tony
