Old 06-29-2007, 04:06 PM
rhodesy's Avatar
rhodesy rhodesy is offline
Stebro Exhaust Install Woes
Just got my Stebro Exhaust today and I've got the gasket "issue."
Can you all please post your workarounds/fixes? I read another thread that addressed the situation, but I didn't get a real clear idea on the best way to take care of it.
Right now the exhaust is at my dealership. Would I be better off taking it to a muffler shop? I'm in the Augusta County area (live) as well as the Albemarle County area (work) here in Virginia if anyone has any recommendations.
Thanks in advance.
Old 06-30-2007, 07:58 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Fixes
I believe that Stebro has changed the mounting area at the front of the longer center section, so anything in here on mounting might be outdated. Didn't they send an installation kit with the system to include gaskets?
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-30-2007, 10:38 AM
rhodesy's Avatar
Nope, just the two sections and that was it. Believe me, it was no fun scouring through the garbage to make sure I didn't miss anything in the packaging...
Old 07-01-2007, 10:41 AM
svxstarship svxstarship is offline
The gasket is a common doughnut looking one. You probably would be better of at a muffler shop.
1999 Audi A8. No more SVX's for now.
Old 07-06-2007, 06:38 PM
rhodesy's Avatar
Problem Solved
For anyone that needs a gasket for the Stebro system in the future, a 2 9/16" inside diameter donut exhaust gasket will do the trick. NAPA Part# is 31508.
Hope this helps future installs.
Sounds sweet!
Old 07-06-2007, 07:54 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Glad it worked out for you! It is one SWEET sound, especially in the 1500~2000 rpm range and again in the 3500+ rmp range!
Enjoy~~
Dave W.
______________________________
1996 Redd
Old 07-23-2007, 09:30 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
I just got my exhaust today,and was told by stebro that all factory subaru gaskets will work,so I hope that is right since I bought them...The rear "bearing gasket being $58!!! I also got the converter from them since mine is starting to leak.It will bolt up just like the factory,has dual inlet's and single out.But there is no oxygen sensor hole. I plan on calling them tomorrow,but has anyone else installed their cat? Do I have to take it to have someone weld one in? Hmmmmm
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 07-24-2007, 06:40 AM
cdvs cdvs is offline
There isn't a sensor on the earlier models. Our 96' has it, the '92s don't.
Old 07-24-2007, 09:29 AM
lhopp77's Avatar
No Emissions
Bought the Euro Resonator myself as we don't have emissions testing.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-24-2007, 08:02 PM
gettin there....
That is what I figured....I called Stebro,and was told the template they used was for a 94. So I have to send the cat back,with a marking to show where the sensor is located and they will weld one in for me...So I guess it's a couple of more weeks for me before I get it done
Mike....
Old 07-24-2007, 08:06 PM
gettin there....
Lee
I also got the euro resonator,I have not matched it up under the car,but Stebro said the pipe was the same as the factory in length. I am taking all the parts to work with me tomorrow to hopefully install the resonator and muffler for now,until I get the converter back from having the O2 sensor bung put in. I AM DYING TO HEAR WHAT THIS SYSTEM SOUNDS LIKE!!!
Mike....
Old 03-07-2010, 07:20 PM
Green1995SVX's Avatar
Re: Stebro Exhaust Install Woes
I'm sorry to bump such an old thread, but I ran into the same problem this weekend when installing my new stebro. I found a gasket which was a perfect fit and was available at my local autozone.
I thought this information would be useful to those who have this issue in the future.
PS - I forgot how great these things sound. Wow!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-07-2010, 07:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
showoff!!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-09-2010, 04:43 AM
Mike are you putting the stebro on your low mileage pearlie? Is the stebro from the catalytic converter back? If you can, Please post some video clips after install!
Old 03-09-2010, 03:21 PM
lhopp77's Avatar
Did you buy the resonator specifically for a 96 or 97? The mounting is different for 96/97 over all other year SVXs.
LOL--see this part is very old. Am curious how his mounting went if for his 97.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
