Old 10-15-2006, 04:15 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
Strange engine problem, need help
Ocassionaly, right after I start to run my car it behaves strangely.
So i'll turn it on and drive it for like 10 seconds when it suddely starts to shutter and jolt. Then it dies. After that it takes a few tries to restart and then if I shift it into Drive or Reverse it dies instantly. So I have to turn it on and let it idle for a few minutes before I can drive it without it stalling. Then it runs a little crappy but after a little time it runs fine. It only does this ocassionaly and it's only started doing it since I installed ECUTune Stage 1. Any ideas?
THanks!
--Mike
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 10-15-2006, 10:15 PM
Manarius's Avatar
Manarius Manarius is offline
Smells like Coolant Temp sensor to me.
-Jason
-Obi Wan Kenobi
Old 10-16-2006, 12:00 PM
Yes that's the most likely problem. This problem really starts popping up as temperatures start to get down to freezing.
Old 10-17-2006, 07:31 AM
Yoda3000's Avatar
temperatures aren't approaching freezing yet but it's definitely started to get colder. I ordered the sensor from AUtoZone yesterday as it was only $20. I did a little research and I may also try resetting my ECU. IT may be upset after the new ECUTune.
-MIke
Old 10-17-2006, 07:38 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
one think you can check too is make sure your air filter is still attached mine use to stall when my air filter disconected
- John
Old 10-26-2006, 09:34 AM
Yoda3000's Avatar
I replaced the sensor and it still has the problem. It starts up cold and acts fine but as soon as I put it in gear (R, D) it dies. I have to idle for a while before it'll run ok.
It's not the air filter.
Old 11-01-2006, 11:02 AM
Yoda3000's Avatar
Do you guys have any other ideas???
I drove it yesterday morning and at the first stop sign I got to it shuddered to a halt and died. After that it took a long time to start back up, and another long time before I could put it in gear and drive it without it stalling.
I really need your help guys!
Old 11-01-2006, 11:27 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Try checking the codes. Do a check engine code, then a separate TCU check.
1995 Subaru Svx L / AWD
Old 11-01-2006, 11:30 AM
Yoda3000's Avatar
How do I check engine codes? It's not throwing any Check Engine Light and it ocassionaly throws the Transmission (Power) light but it's been doing that since I got it.
Old 11-01-2006, 11:36 AM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
Here is a link from the "How-To Documents" on how to check the engine codes.
http://www.subaru-svx.net/photos/user.php?How-To|14264
Click on "Check engine code instructions".
Old 11-01-2006, 05:35 PM
Yoda3000's Avatar
Sweet thanks, i've never done that before.
It's throwing codes 23 and 29: Air Flow Meter and Crank Angle Sensor.
How difficult are these things to fix/replace? I assume it's the latter (29) that's causing my problems.
What is the air flow meter? Is that the MAF?
Old 11-02-2006, 07:48 AM
I haven't replaced either but I would guess the MAF is easier to replace. Neither should be difficult though.
Old 11-02-2006, 08:02 AM
msvx95's Avatar
It's just a phase
The MAF should be that big square thingy that sits on the big ol plastic tube thingy that comes out of the air box that has your air filter in it....should be easy to replace ( I think )
Old 11-02-2006, 08:43 AM
Yoda3000's Avatar
No i really don't think it's a MAF problem.
Does anyone know the part # for the Crank Angle Sensor 2? How hard is it to replace once I have it?
--Mike
Old 11-02-2006, 09:38 AM
msvx95's Avatar
It's just a phase
Looks like p/n 22053AA020 168.00 bones on subaruparts.com
Not sure how difficult to replace...I have never had to yet..Prob. have to take the timing belt cover off to see it I think. It should be located at the front center of the engine.
