Old 01-27-2002, 03:10 AM
TonyShaleUK
Steering and struts
Hi
I'm new to the club - been with the UK lot for 6 months since buying my silver 91 Jap import. Put 11000 exciting & trouble free miles on since then, but..
The rack needs replacing (worn inner joints). I have one to replace and altho' it looks straightforward, getting it out of the subframe looks a nightmare! Any advice - engine raise or subframe drop??!!
The strut bearings need replacing. Does the spring need compressing to remove the strut?
Seen a lot about the steering o ring replacement - which one is this? Rather do it with the rack out than in!
Thanks in anticipation
Tony
Old 01-27-2002, 08:04 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
You don't need to replace the entire rack in order to replace the inner tie rods - that would be overly expensive and difficult. The inner ends are threaded into the ends of the rack.
The spring doesn't need to be compressed to remove the strut from the car, however it will need to be compressed in order to replace the bearing plate, etc. I would really recommend that compressing the spring be done at a service facility as the inexpensive strut spring compressors are very dangerous. Usually if you remove the strut from the car and take it in to a garage, etc. they'll change it out for you for a small fee.
Old 01-27-2002, 12:01 PM
Re: Steering and struts
Originally posted by TonyShaleUK
Hi
Tony
Tony
When the O-ring is mentioned in connection with steering, they mean a small ring between the reservoir and the steering pump.
The tank/reservoir has to be emptied[using a turkey baster is recommended], the tank taken off and the O-ring seal replaced. The cost of the ring is cheap. A leaking seal causes cavitation in the pump, which can be felt as vibration at the wheel under lock, or sometimes groaning or growling at the pump.
Can be tackled anytime, whether the rack is in or out.
PS, when refilling, take care to use Dexron ATF, not power steering oil.
Old 01-27-2002, 01:02 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Tony,
Welcome to the Network. I've been a part of the UK club as well, but haven't frequented it as much as I used to.
If you go to the top of the page, you'll see a button for "Personal Lockers." If you click on it, you will be sent to a page with everyone's "locker." Scroll down to the "How-To" locker where you'll find a step by step how to on the o-ring replacement as well as a picture showing the location on the Power Steering Pump reservoir. Best of luck.
Randy Johnson
Mike Davis -- at Reading VI
