After market alarm install document
Before a panel of my peers, I submit this document for review and possible inclusion into the Hall of How-To (as soon as it reappears).
This document shows how I installed an aftermarket alarm using the stock wiring harness. This would be great for those of you whose stock unit has died or for those of us who never had one. The document is meant to help installation, not as an instruction manual, therefore alot of the minutiae was left out. Let me know what you think and any suggestions to make it better. I am committed to decent documentation. Special thanks to lee for his pioneer work in this field. SVX alarm install
'95 Subaru SVX L-AWD 88K miles. |
thanks for the honorable mention...good work
Why are there diodes reverse biased on the doors?
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
I can't answer about diodes from an engineer's viewpoint, but maybe you can get what you want from this site:
http://www.the12volt.com/diodes/diodes.asp |
This looks great. I've been wanting something like this for a while. Thanks!
Great job, Nate! With the price of SVX alarm modules (and their tendency to die) I've been thinking of this for awhile.
If anyone has a dead alarm module they'd like to donate, I'll look for the proper wiring connector to use, so the wires will be locked in place. UPDATE: I have the matching connector. E-mail me if interested. Also, "Tuck" kindly donated a couple of dead modules for me to dissect.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses Last edited by SVXdc; 04-01-2010 at 10:18 PM. |
If David is not able to get the plug, here's what I did. Since my alarm box was dead I pulled out the circuit board and de-soldered the connector, then soldered on the connecting wires from the DEI alarm I replaced it with. A little shrink wrap to cover the connectors and it's done. The OEM wiring harness then doesn't have to be cut or tapped. I even used the stock alarm LED, although every once in a while I think about putting in the aftermarket LED that came with the alarm. I haven't because I can't figure out where I could mount it prominently without causing irreversible damage to a panel. |
Lee, Depending on what David says, I may go with your suggestion. My factory alarm is acting up again. Everytime I drive in the rain, the alarm starts going off. Its the most annoying thing ever. And its an almost brand new alarm.
The shock sensor was set at max and I didn't think about turning it down until we had a thunder storm and my wussy car sat outside and cried. Over and over and over and over. Nice things about the Prestige: 1. Very adjustable settings like horn duration for sqwuaks. The SVX needs the full 30ms to keep the horn from sounding weak. 2. Silent arm and disarm. 3. Internal relay for parking light flash. These are pretty typical options though. The main reason I went with Prestige...it was the only non-crappy alarm I could find in town.
-adding up a talking device in case of proximity -long range remote control. does it offer these options? i looked for it on ebay, is it http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
I am by no means an alarm expert as I did the bare minimum amout of research on my purchase. If I were you I'd ask 'rmjjensen' what his ideas are. I believe he does alarm installations professionally and would be better versed on this.
Thread Tools | |
Display Modes | |
