Old 06-29-2003, 07:39 PM
exhaust diameter 101
My friend and i were recently discussing exhaust modifications and the question of increasing the diameter in the exhaust pipes were raised. If one were to replace the entire exhaust system from the headers back, and wished to increase the diameter of the exhaust to 3 in. Would this be possible?
Old 06-29-2003, 07:45 PM
Subafreak's Avatar
Superbeast
Possible yes, but not comming off the manifolds. 2 1/4 is plenty big for a N/A 3.3 anyway.
Old 06-29-2003, 07:47 PM
what is the stock diameter?
Old 06-29-2003, 07:52 PM
Subafreak's Avatar
Superbeast
I ment 2 1/2. I think stock is between 2 1/4 and 2 1/2. Of course I have duel 2 1/4 from the manifold back, that would be like running one 4 1/2 pipe! I think I need a S/C to make it worth it.
Old 06-30-2003, 01:01 AM
mbtoloczko's Avatar
sans SVX
From the third cat back, the stock ID is about 60 mm which is about 2.35 inches. For a near stock SVX motor, going up to 2.5" inch ID from the third cat back is a good option. This increases the crosssectional area of the exhaust by 10%.
Mychailo
Visit my locker
Old 07-01-2003, 08:09 AM
GreenMarine's Avatar
From POST-***** to LURKER
Yea, that is a good idea... going to 3 inches though on a N/A car just isn't really nessasary.... You'll probably get a big Hp increase up around Redline but you will loose so much torque down low it won't even be funny.....
Old 07-01-2003, 08:41 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
3" is probably fine for the 3.3l
considering that 2.25 is optimal for the 2.2l that this is based off of
and 2.5 is optimal for the 2.5l engine
you might wanna try 2.75 tho everyone always jumps from 2.5 to 3
SV What?
Old 07-01-2003, 09:20 AM
mbtoloczko's Avatar
sans SVX
I would be more inclined to try to correlate exhaust diameter with horsepower which is going to be more closely related to the amount of exhaust gas produced than actual engine displacement.
Mychailo
Visit my locker
Old 09-27-2003, 09:05 PM
Just going through some old posts here and noticed a flaw in your math. A dual 2 1/4 exhaust is not equivalent to a single 4 1/2 exhaust. A single 4 1/2 has twice the cross sectional area of a dual 2 1/4 exhaust.
A single pipe equivalent to a dual 2 1/4 exhaust would have a diameter of approx 3 3/16.
Old 09-27-2003, 11:27 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
ive run open headers at hte track(uniongrove, w/o nitrous) and recieved a .1 second increase. I reset and let hte ecu learn to the gas station and back(15 miles) There is virtually no restriction in our exhuast, and it seems to be give here take there. I must say that our engine sounds quite agressive without exhuast, my friends said it sounded like it was gonna run tens!!(but it ran 14's...who are we kidding here? )
phil
~Phil
Old 09-28-2003, 08:13 AM
Subafreak's Avatar
Superbeast
I never was any good in math
Old 09-28-2003, 08:42 AM
immortal_suby's Avatar
Thread Killah
Originally posted by Phast SVX
ive run open headers at hte track )
phil
Please tape record that the next time you try it. That must sound awesome.
Locker Link
2015 BRZ Limited 6MT
Old 09-28-2003, 05:21 PM
[QUOTE]Originally posted by Phast SVX
[B]
Phil,
Possibly the 0.1 second resulted from practice gained as a result of the previous runs ! On second thoughts I am not sure if you by "increase" you mean an improvement or a longer elapsed time and therefore decrease in performance!?
In any event, the above should be shouted out loud from the roof tops, included in the How Too section as a "How Not Too" and posted in Mod Mania for good measure.
I have always been confident that the stock exhaust system is obviously well designed and is in fact a carefully tuned system and that anything fitted by an aftermarket exhaust shop will be an absolute downgrade.
Congratulations, Trevor
Old 09-30-2003, 12:27 PM
NomadTW's Avatar
open headers is not as good as running a straight pipe. cut your exhaust off at the axle... then test it out...
with open headers you will loose the scavenging effect and all of the exhaust gasses will not be pulled from the engine in time for the intake stroke and exhaust gasses will be pulled into the combustion chamber... there is less oxygen in exhaust gasses than in air.. duh... this will hurt performance
back pressure is bad yes... but exhaust flow velocity for scavenging is very very important
SV What?
Old 09-30-2003, 04:00 PM
I agree absoutely and what is explained illustrates why the original system works so well. It has been designed accordingly after a great deal of practical testing to an extent beyond the capability of any after market exhaust shop. What is more it is obvious that the original design has not been compromised on the basis of cost.
A properly tuned straight pipe system would result in improvement but as it is not possible to run one on the road, the comparison with open short pipes is valid.
