Old 04-25-2003, 12:54 PM
RSVX RSVX is offline
Network Design Administrator
Check Engine Light
OK, so I start the car this morning and I look down and see a little red check engine light on... and Im sitting here thinking, I have never seen this on before.
I also nothing that the car seemed to be idling a bit high... ie 2000RPM. So as I stair at it thinking, damn I have to go to work, and I am already late!! I tap the gas and it goes away... so thi leads me to think its teh Throttle Position Sensor...
Am I right? My car has also been idling a little rough as well... would this contribute to that?
How much and how easy to do on your own? Keep in mind I used to fix jets for the Air Force, so I know my way around tools...
Life is a game. Play to win.
Old 04-25-2003, 01:30 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Check Engine Light
Run the self diag first, to be sure. I'm thinking it may just be an O2 sensor, The rough idle may be simply due to a dirty throttle body. Do the diag first, and take it from there.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-25-2003, 02:02 PM
Re: Re: Check Engine Light
A RED Check engine light? I thought they were all yellow...
Old 04-25-2003, 02:05 PM
Aredubjay's Avatar
Re: Re: Re: Check Engine Light
My check engine light is RED-- BRIGHT Red. You know if it were yel . . . the other color, I wouldn't be able to stand it.
Randy Johnson
Old 04-25-2003, 02:14 PM
I stand corrected, sort of. I went out to my car and turned on the ignition, all the indicators were red EXCEPT for the check engine and ABS, which are bright ORANGE.
Once I replaced the 2 front O2 sensors the CE light went out, but all the way to Reading and back it was my constant companion.
Old 04-25-2003, 02:17 PM
Aredubjay's Avatar
Interesting. Mine's STILL RED
Randy Johnson
Old 04-25-2003, 03:08 PM
I second the cleaning of the throttle body!
Pull the code though.
Old 04-24-2006, 08:33 PM
ted_garlock ted_garlock is offline
How to get Check Eng. Codes
Hi, I've been lurking here for quite some time, but this is one of my few post(s) (I'm not even sure if it should be plural). Anyway, my 1992 LS-L has sometimes had the Check Engine light come on, then I turn off the car, unplug the MAF, plug it back in, re-start, and all is good. This morning, the un-plug, re-plug method did nothing. Can anyone link me a site that shows how (as in where the connector is) and what the corresponding codes mean? The link above doesn't work. My previous method leads me to believe that it's the MAF, but I could also have bad O2 sensors, or whatever else. I just don't want to put up $250 for a MAF if I only need O2 sensors. Most likely, I will replace them both, but the question is in what order. Also, what brand(s) do you guys reccomend for replacement parts. Budget is a concern because I spend most my fun money on my motorcycle, and have the SVX as winter time fun. Thanks - feel free to PM me if you don't wanna post any info.
Old 04-24-2006, 09:10 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
my CEL came on recently as well. I looked in the how to section and tried to pull the code by using the kickpanel method and the blue wires. the only problem is that the hole i'm supposed to plug the wire into doesn't have anything in it, just plastic. It didn't work. I'm guessing that this is because i have an obdII svx. Does anyone know how i can pull the code? Thanks!
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 04-24-2006, 10:23 PM
alltrac alltrac is offline
OBDII code reader. Most autozones have a tool loaner program or you can buy one.
Victor
Old 04-24-2006, 11:12 PM
I have access to an OBDII code reader. I tried hooking it up but the reader didn't get past the welcome screen. It is an older snapon scanner where you have to put the cartridge into it. I put the cartridge for asian import into it and there is another thing where i hook in a chip and there are a bunch of different chips that could possibly go in there. I hooked it up and never got past the welcome screen. I should just take it into the shop.
EDIT: its a snap on MT2500
Old 04-25-2006, 11:34 AM
Welcome to the site! I updated my expired link above. The new site is http://svx-iw.com/ and you must click the "SVXipedia" link to get to the codes section. Let us know your results or if you have any troubles.
Old 04-25-2006, 08:01 PM
I thought so too. But then I realized I only owned 94 model SVXi. When I got my 1st 92 I noticed the extremely red CEL so all 94+ SVXi have yellow CEL's while 93's and 92's are red... Case closed
Old 04-25-2006, 08:04 PM
Are you plugged into the connector on the bottom of the dash on the pass side of the steering wheel??
Old 04-25-2006, 11:48 PM
That is awesome! Thanks a lot.
