#91
Tom |
#92
Sorry.
In my post, I made mention of the fact that the SVX caliper mounts sit further out than the WRX. Hence, where the STi 4 pots on a WRX have a 295mm disc, the same calipers on an SVX require about 320mm. If you go to the Brembo's, (which on an STi require a 320mm disc), by the same logic, you'll be needing something like about 345mm disc. That's one big disc. Matt |
#93
Well maybe the Brembos are made for our hubs... Maybe I will be able to get a HUGE rotor to fill my 18's... who knows
Tom |
#94
finally got a chance to fit up the Brembos today... Once again, not fully but good enough for me to be confident... I fully believe now that the STi brakes are a direct bolt up to our hub. I will go ahead and complete my order for the brakes and I will order a new set of rotors with the 5x114.3 lug pattern to fit em up... good news for all of us
Tom |
#95
So bolt holes line up...that's great news, and as I had hoped.
Good luck with the more formal test. Matt |
#96
I compared diameter and offset of the rotors as well. This is why I am confident that with the 5x114.3 rotor they will bolt on directly with no spacers or special brackets
Tom |
#97
so you got the set off the earlier STi I guess? The newer one has the 114.3 PCD, so yours are the 5x100? you could just get them redrilled to suit.
Matt |
#98
I just tried an STi caliper at the dyno since the operator was nice enough to let me borrow one of his old ones. It was his rotor. I will be getting just calipers from my source and new rotors for the 05+
Tom |
#99
So... to clarify everything. The calipers were from what year STi? And were they USDM calipers? The rotors that you are getting are from an 05+ STi?
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#100
from an 04 USDM Sti. I am getting calipers from a JDM sti ver8 dunno what year... The calipers are the same between the JDM and USDM cars from what I understand but I am still waiting on rotor thickness confirmation
Tom |
#101
Now your only consern will be rim clearance over the caliber.
#102
#103
So, assuming that one has a set of 2005 STI Brembo calipers, what rotor diameter would one need and what wheel size would be required to clear the caliper?
From this thread, seems like there was a major caliper change from 2004 STI to 2005 STI. I think I understand that the 2004 STI calipers would require a 320mm rotor on an SVX, while the 2005 STI calipers would require a 345 mm rotor. The 320mm might fit under a 17" wheel, while I would bet the 345mm would require an 18" wheel.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 12-21-2006 at 12:02 PM. |
#104
actually the only change in the 04-05 was the bolt pattern I firmly believe that was a mis-print on the page. So I think the calipers are the same but the bolt pattern on the rotors was different. I wold check Nasioc before being compeltely sure
Tom |
#105
I think you're correct in saying that it was a mis-print. Several '05+ STi owners run 17x8" Rota wheels (Torques, Boost, etc) with their stock calipers & rotors.
Thread Tools | |
Display Modes | |
