#61
I wish I had done some big single setups so I could add some input on the larger turbos...I've never done anything huge, but the twins on my VR-4 don't spool until the high 3k range but when it comes on it comes on FAST...I'd love to see what the extra .3L the SVX has does to that number. This is going to be a FUN project.
#62
I don't think that the 4094 will be THAT laggy on the EG33.... I have seen dyno sheets and videos of EJ25's that have a GT40 series turbo and they are hitting 16-18psi at 4k I think it was. With an extra .8 liters of displacement I would like to think that I would be able to hit 20psi @ 3700-4000. With a redline of 8k I think we would be okay.
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#63
With an extra .7L tacked onto the 3kgt engine, our guys have seen their boost about 1000RPM sooner (and being that the 3.0 is a larger engine to start with, we've got a much greater % increase in displacement in your scenario). I think it will be a very nice setup if those spool numbers are accurate that you found on that 2.5
#64
1/4mile or highway run car it's the way to go if you're looking for stupid power and don't care about the twisties. Again I'm not trying to sway you to one decision or another, just trying to help you get the most of of what you're doing. I do this stuff for a living and just want to give you clear cut info on what I know and deal with making and developing setups that you're looking to do on the SVX. Last edited by Boxersix; 11-30-2007 at 11:15 AM. |
#65
I would really like to see how you do this. I might give this a try some day. Should be pretty easy to do with the stock headers.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#66
#67
I think it is worth trying high boost on the stock motor. I would just expect to have to replace the pistons someday. Tom and I have both had the experience of blowing ring lands. In fact this is a common problem with the Imprezas as well. The good news is I didn't have any major sleeve damage as a result.
#68
#69
Also, boxer6, please just keep talking/ posting too. You obviously know what you are talking about and have a lot of experience. My S/C was my first real endeavor with forced induction and now to be looking a the new world of turbos........ Yeah, a lot to learn.
#70
That won't be a problem at all since this manifold design will only work on my 962 chassis and not an SVX engine bay(not worried about people copying it ![]() ![]() Quote:
HAHA ![]() ![]() Ok so you ARE planning on building this as a drag car system.....then yea the GT4094 will probably suffice for your needs. Sure as heck would be too large for a circuit car like I build but for a drag car once it's spooled it's inertia will keep it up there which is perfect for a drag run. EG33 spinning out to 8K rpm with stock valvetrain and PCM???? Elighten me on that one as I'd love to get even a 72-7500rpm limit on this 962. If not stock valvetrain, what the hell are you using up top for springs and retainers? Who remaps the stock PCM to up the rev limit? I'm not aware of any open source tuning for the EG33 PCM....but then again remember I'm a Porsche guy and don't know the Eg33 like you guys do ![]() |
#71
I don't really see how this would layout would translate to a 6 cylinder twin scroll compressor housing application, but it would seem to me the best and easiest way to mimic this on a 6 cylinder would be to use the stock manifolds and run two equal length headers to the turbo. Would probably require a special fitting to properly plumb the two pipes into each scroll of the turbo to keep the lines separate.
#72
#73
To piggyback sicksubie, on the intake question; is it even possible for our intake to be extrude honed? I know all the z32's did that as the only option, but they also didn't have a iris in their intake.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
#74
That picture was just to show how the pulses are kept separated as long as possible before going through a collector. Doesn't matter if it's a Subaru flat 4 turbo, or a Porsche flat 12 turbo. The benefit of a divided housing is to keep the exhaust pulses isolated from one another as long as possible before the turbine. This delivers more energy to the turbine for faster spoolup. The EG33 stock manifolds will not work well for this as they mash the exhaust pulses together too soon to be effective in any sense in a twin scroll housing. Plumbing the exhaust from the OEM manifolds into a divided housing would just be a restriction and more than likely reduce power on the top end. You need to separate the pulses longer to make the system effective and use all the benefits of a divided setup. That's the reason why the FR twin scroll setup in the picture you linked to pulls each pair of runners from opposite sides of the head as the firing order of an EJ25 is 1 3 2 4....again keeping the pulses separated as long as possible(cylinders are grouped as 1+2 and 3+4). Another thing to remember with a twin scroll manifold design is the primary diameter is normally smaller than that of a standard housing setup as you're looking for exhaust velocity and low expansion until the exhaust reaches the turbine. Using a typical primary size of a standard setup and you'd lose that velocity, gaining nothing in the end. If you're going for all out power a divide housing is not in your best interest. If response is your game, so is twin scroll. You most definitely can use the OEM manifolds for a standard turbine housing though and I'd go that way as it's cheap and easy and the reversion in those manifolds has been "tuned" by subaru's R&D. No need to mess with that too much. Just match an appropriate A/R and turbine to your needs and you're set. |
#75
I doubt that I will be using the stock manifolds. I may be speaking to early though.
Thread Tools | |
Display Modes | Rate This Thread |
