Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #46
Old 09-22-2004, 04:39 PM
mikecg's Avatar
mikecg mikecg is offline
Re: It's your car?
Originally posted by NeedForSpeed
Longassname,
That looks like your car? I thought the first Stage 4 was for a customer car?
It's for my car. However, My car is my daily driver and it is about 2000 miles north of Miami. He's doing all the set-up work on his engine and car. When he's got everything ready I'll be taking vaction time from work to drive down to have it installed and the final tuning done on it. (I think he's scaming a stage 3 for himself, too)
Old 09-22-2004, 04:42 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Re: It's your car?
Imagine if Longass runs a Stage 3 kit along with the NOS package from the Stage 2!!! He'll have a traction-limited 11 sec SVX...
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-22-2004, 06:55 PM
NeedForSpeed NeedForSpeed is offline
yezeree,
That's what I thought. But you don't think he's going to do all that and then put your stock intake back on his car? No, if I were betting on Michael, there will be two Stage 3's, and none to soon. Michael, you must get a kick reading these posts!
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 09-23-2004, 03:27 PM
It makes more sense to build 2 Stage 3 SVX's right off the bat. That way when a problem shows up with one it can be determined more easily if it is car related or design related.
Old 09-23-2004, 03:33 PM
EddieSVX's Avatar
EddieSVX EddieSVX is offline
shiftin' an automatic
Send a message via AIM to EddieSVX
Re: Re: Re: It's your car?
yezeree,
Let them take their time... It will take me time to save up for it.
Well, I'm also considering that whole JDM 2.0 STi with 6 speed tranny and rear diff deal for $9700 CDN shipped... hmmm...
Eddie
'92 SVX LS-L (For Sale! Info and link to pics... ) #9536 blt. 4/92 (late boomer '92)
'01 Audi S4 (2.7L Twin Turbo - 6MT)
Old 09-23-2004, 06:24 PM
It would make better sense if one of them were mine.
Old 09-24-2004, 12:32 AM
longassname's Avatar
Just some dude.
Today we have pictures of the fuel pump install. We installed a Walbro 255 lph fuel pump in place of the factory 140 lph fuel pump in order to supply enough fuel for our demands.
The fuel pump is submerged in the fuel tank along with a whole bunch of fuel level sensors and brackets. There is an access panel behind the rear seats under the trunk carpeting.
After removing the access panel you can see the fuel hoses and the lid to the fuel tank used to access the electronics which are in the tank. Unlike the WRX our fuel pump and metering electronics are not attached to the lid but are on separate brackets inside of the tank. There are 3 brackets inside of the tank. 1 bracket has the fuel pump on it, the 2nd bracket has a fuel level meter and fuel pickup on it, and the 3rd has another fuel level meter and the jet pump (uses suction from the fuel return line to draw fuel from the pickup on the opposite side of the tank).
I didn't take any pictures inside of the tank. Here you can see the lid from the tank removed and the fuel pump assembly (the 2 metering assemblies remain in the tank). I have already switched the pump out at this point. The smaller silver pump now mounted in the assembly is the new 255lph pump. The larger fuel stained pump sitting next to the assembly is the old 140lph pump.
Since this fuel pump is intended for a WRX the wires are shorter than we need for the SVX. I didn't have any other wire handy so I clipped the ends off of the old wires and used the body of the old wires to extend the new wiring. I of course heat shrinked the connections to make sure no shorts could happen (positive metal contact touching negative metal contact). At this point some of you are probably wondering how come all these electrical connections can be submerged in the gas tank without shorting out. Remember not all liquids are the same. There's no water in gasoline; it's actually hydrocarbons and it isn't conductive enough to cause shorts.
With the new fuel pump the fuel pressure is raised 5 or 6 psi accross the board. I can adjust for this in the constant I will be adjusting for the new fuel injectors. This will have us running around 35 psi at idle and 48 psi at full load which will work nicely.
Old 09-24-2004, 09:59 AM
EddieSVX's Avatar
Thank you! Just what I needed to start my day.
Eddie
Old 09-24-2004, 10:14 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
looking good. love that camera too
phil
~Phil
Old 09-24-2004, 10:48 AM
Chiketkd's Avatar
Never knew Michael was an audiophile. With that amp in the back, his car will go fast and pump-out some *tunes*!!!
Old 09-24-2004, 11:18 AM
BoondockSVX
o/t: I'm pretty sure water is only conductive when you add salt. Pure water is non conductive...right? I can't remember.
Old 09-24-2004, 12:09 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Michael,
You do realize that the fuel pump upgrade would be an interesting upgrade to those SVXers that are using a good extra does of nitrous right? Or even those folks like SVXtasy who's turbo'd who who'd like to go turbo. You could make a couple of extra bucks selling those already made up to be fitted to an SVX, while you are making this monster. Just a thought!
Kevin Thomas
***R.I.P***
Old 09-24-2004, 12:15 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
whats the intake manifold look like...
Old 09-24-2004, 12:42 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
What about people who get electrocuted when they try to microwave a burrito in their bathtub?
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 09-24-2004, 12:46 PM
No, No, No, they try to microwave the hair dryer!
Display Modes Rate This Thread
Rate This Thread:
