Old 08-06-2009, 09:46 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: click click click...start? click click start!
I was always taught to start with the basics...... check the starter and starter connections before going deep into complicated electronic systems.
Old 08-07-2009, 03:55 PM
ScottyB's Avatar
ScottyB ScottyB is offline
Well I am doing the bosch relay mod as well, but I couldn't find a bosch part number in any of the threads concerning the mod. I asked a guy at napa for a 30 amp relay and he showed me a book will a whole bunch of them and asked which one I needed and I said 'good question', so... does anyone know the bosch part number? Thanks
97 Toyota 4Runner SR5, 5 spd
92 Ebony SVX AWD (4.44 gears)
Old 08-07-2009, 05:46 PM
kwren's Avatar
kwren kwren is offline
You are right, of course. We have to do more testing to rule out the starter and other components. Always!
Keith
Old 08-07-2009, 05:47 PM
kwren's Avatar
They normally keep the bosch relay on the rack with other components. If needed, can get the # for you.
Keith
Old 08-07-2009, 05:50 PM
kwren's Avatar
Originally Posted by oab_au View Post
No mate You introduced that one.
I believe we are talking about the starter solenoid circuit. Sure starters do have problems, but I don't think I would be over stating it if I said that at least 90% of all SVXs that experience, just a click, when the key is turned, have the trouble that I have suggested, and will be assisted by adding the Bosch relay mod.
Absolutely, Harvey!
Keith
Old 08-07-2009, 06:27 PM
ScottyB's Avatar
It would not be a 30 amp relay... far from it!
Keith
That would be great! I went to autozone and checker and they said they both stopped carrying them and that napa would have it, so I went there and then there were just too many choices
Old 08-07-2009, 08:49 PM
kwren's Avatar
I will go by napa's warehouse and get a # tomorrow am Not sure about the amperage rating but don't think it is a 30 amp circuit? Just not sure. Will know tomorrow.
Keith
Old 08-07-2009, 08:58 PM
kwren's Avatar
you would probably want it with a mounting bracket
http://www.opentip.com/Electronics-C...-p-878391.html
If this doesn't work let me know
Keith
Old 08-07-2009, 09:01 PM
kwren's Avatar
might click the link and print the page and take it with you to the auto parts store.
The relay has the numbers of each connection and shows what the function of each part of it, right on the relay. The numbers should correspond with the numbers on the Busch starter wiring diagram that is floating around.
Old 08-08-2009, 12:27 AM
ScottyB's Avatar
Sweet! Thanks Keith, i'll go do that
Old 08-10-2009, 08:58 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Originally Posted by TomsSVX View Post
thanks Tom
i'll try this on the weekend....
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 08-23-2009, 12:36 PM
STORMINORMAN STORMINORMAN is offline
Lightbulb Re: click click click...start? click click start!
There are two other possibilities for this type problem, and two solutions:
the ignition lock/key assembly fits into the cast housing behind the "security cage" on the steering column. Even the newest SVX's are a dozen years old, now. On my car the key could even be removed while the car was running. At the other end of this cast housing is an ignition switch & pigtail that can look good from the outside but cause the exact symptoms described.
I replaced both. It is a good idea to replace the headless "security" screws/bolts with regular bolts or to cut a flat blade screwdriver slot in these fasteners to facilitate removal and tightening. Mine were always coming loose (easily determined when the entire ignition lock assembly rattles and moves around).
I was told I "needed a new starter" for about 10 years, from 3 different shops: my original starter works wonderfully and has for 17 years and almost 175,000 miles.
Cheers!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 09-29-2009, 08:36 PM
SomethingElse's Avatar
word words wording
Trevor, I am just dying for the day that you hop in your SVX and start the engine, rather try to start the engine and you get the click that so many of the rest of us have experienced! Not wishing you any bad luck because this is one of the cheapest and easiest mods possible.
When this happens, please take your camera to the auto parts place and get us a picture of you standing at the counter with a Bosch relay in your hand and give us a big smile while the camera clicks away. Another "not so bad click".
On your post, please end with... Please see attachment! Cheers, Trevor!
Keith
this day will never come
Eric
