Re: Headed to VIR June 13,14
Anyone have any input on tire pressures?
Back in the day we used to run 31 ft 33 rr (hot lap temps) but those where on rwd cars.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
The SVX is a heavy car and you want to be very careful about rolling over the sidewalls. With ultra high performance summer tires, you want to see a hot tire pressure in the low 40's. The rears should be 3-4 lbs less. Usually your cold to hot pressure rise will be 5 to 6 lbs front and a little less on the rear. Suggest you try the white shoe polish tool. Paint a couple of stripes of white shoe polish on each tire, running from the tread up the sidewall to the wheel. After you come in from each run, see how far up the sidewall the shoe polish is scrubbed off. If it's scrubbing up the sidewall put in more air.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I don't think there has been enough emphasis on the brake fluid. It is a MUST to completely change the brake fluid within six months of running a track event - and with a good high temp fluid. You need one that boils at over 500 degrees, nothing less. Different people like different brands, but read the label about the boiling point ...... One does not need the brakes to fade going into a turn at 100 MPH. Remember too that VIR has a mile straight you'll be on .... Harry
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
I think ill be okay as far as brakes. we plan on bleeding them after every session. I have some race track experience (crew cheif) ill notice when the brakes start to fade. Im not pro enough to put the expensive crap in.
guess ill start around 37 psi in front and 39 psi in rear and paint a white mustache on my tires. starting to get butterflys got the red stuff on the front and green stuff on the rear if anyone wants to know...guess well see how it goes.
One more thing. Tape over your license plates. Have heard rumors that insurance companies have been known to take pics at the track, to build their database for possible denial of future claims. At my last NASA track session, we were advised by the NASA staff to tape over the plates .
WOW! that was the most fun I had since the first jet ski ride in the ocean.
It was a great experience! Each and everyone of you suck for not being there.... Its not easy being the only SVX around and having everyone asking you the same stupid questions. what is that?
Tom |
I got spanked hard by a 240 with flames shooting out of its exhaust. honestly i got spanked by everything the first day. On a happy note, my last run..i passed a vette,charger (twice cause I pitted to check for damage),couple miatas, bimmer, and a mini cooper...spanked or stayed ahead of everyone in my group. When your in the groove hitting all of your braking points and turn in points...110+mph on the straights... all 4 wheels controlled drifting through the "S"-turns at over 80 mph slammin apex's...its an in-describable feeling. pics should be here tomorrow.
Yea, it was a trip to be able to do things like that at those speeds. Talk to Shotgunslade, he has been able to keep up with a lot of competative cars in his mostly stock SVX... From what he has been able to share with me it is speed through the turns and acceleration from them that will keep you out in front. Oh and a heavy car is no excuse... It just needs to have more power to push that sled
Tom |
I would need a supercharger...inter-cooled. And the nemisis, the things SVX dreams are made of ...still gotta hack off at least 200 pounds somehow. definalty more..
hmmm doing research..benebob? hocrest? cars down to 2700 pounds? is that true?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click Last edited by SomethingElse; 06-16-2009 at 08:50 PM. |
#28
Welcome. You're hooked. Going to NJ Motorsports Park this weekend. Taking the roadster, not the SVX. Been to the track not nearly enough this past year due to car woes. Overheating SVX and breaking roadster.
#29
Thanks! I am hooked and way behind.
I didnt overheat thankfully but I did have coolant underneath where my battery tray should have been. It was not coming from the hose or the top of the coolant jug...where did it come from?
#30
Probably boiling inside the block blows coolant out the top of the overflow tank. That's what mine does.
Thread Tools | |
Display Modes | Rate This Thread |
