Re: Grrr.... new tires installed, still vibration.
I have had many people balance tires and then drive them to find out they are not really that good at speed. Bubble balancers are inexpensive and easy to use. I think I would use a tape weight in the middle of the rim on the inside to compensate for the static. After a good two plane balance is done this would be a check on the static. Peace, John
Found a local guy who said he would do it for $50.
I'm going to pick up a loaded caliper from Napa permitting they have one. Seeing as there is a brake caliper kit listed way below that, will I need that as well or just the loaded caliper? Also, will having a new brake pad (loaded caliper) create any issues with the driver side, already half worn brake pad? Should I go unloaded? Thanks in advance...
1994 subaru svx le 112k |
Caliper isnt had you could save 50 dollars =D Bleed it is the fun part.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Bleeding was a pain... I got a set (4) russell speed bleeders and it was SUPER easy especially if you dont have anyone to help you. Well worth it IMO
1992 Liquid Silver/Black LSL LeveL10 Stage 3 Trans and associated stuff |
Thread Tools | |
Display Modes | |
