Old 04-08-2005, 09:53 AM
immortal_suby's Avatar
Thread Killah
Originally Posted by pavanbabut
Hi,
If you dont mind and if you can make some time, can you tell me how to do this stuff. I am little bit inclined to do this if I can do it in some reasonable time.
thanks,
-Pavan.
Beav explains how to remove the intake in this thread
http://www.subaru-svx.net/forum/show...intake+removal
Once removed use a good spray cleaner - I recommend valvoline synthetic cleaner based on a pepsi challenge I conducted. It cleaned way better than the other stuff.
You'll want to have new intake gaskets ready. I have been able to reuse mine sometimes, and other times they come apart.
Also be prepared the first time you do this with some bulk vacuum hose. I think they are 1/8" - you can find this at most auto stores.
You will find many of the vacuum hoses underneath the intake will be brittle and cracked. For this reason alone I recommend removing the intake just to change these hoses - I bet alot of svxers are losing vacuum and don't even know it. Be very careful with the plastic fittings underneath the intake, they are fragile.
This would also be a great time to change out the PCV valve since it is on the underside of the intake.
After the intake is cleaned and put back in place be sure to change the oil fairly soon. The spray that leaks down past the rings needs to be cleaned out asap.
Please note that removing and reinstalling the intake is a major pain in the neck the first time you do it. ?Not for the mechanically challenged. I can do it pretty easily now but I remember that first time it took me a very long time and alot of work.
Locker Link
2015 BRZ Limited 6MT
Old 04-08-2005, 01:28 PM
pavanbabut's Avatar
Hi,
May I know how much it would cost for me to do this stuff (approx.)
And can u tell me if you can, whether doin this may overcome some of the problems that i am sensing on my car (in post #13) to atleast some extent.
thanks,
-Pavan.
Old 04-08-2005, 02:42 PM
Thread Killah
Check subaruparts.com for prices - not sure what they are but it should be under $50
It may or may not help the problems you describe - it all depends on what kind of shape your engine is in now.
Locker Link
Old 04-08-2005, 03:05 PM
drivemusicnow's Avatar
Poor College Racer
Something i've heard from MANY people that is quite effective at cleaning fuel system, cylinder walls, and intakes is that "sea foam" stuff. basically you can either put it in your gas tank, put it in your oil, or put it in through a vacuum line in your intake. all three ways have proven to be effective for people. they say wait till night time before you do it through the vacuum line because it blows out a massive amount of thick black smoke from all the build up.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
