Old 04-16-2004, 09:32 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
one word.
FRONT MOUNT
oh wajt ahhh **** it!
~Phil
Old 04-17-2004, 12:14 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
PhastSVX, good find. I was also thinking that he was running the intake piping underneath his whole set-up and the front-mount intercooler supports that.
I'll also say this - if this guy was able to dump this much money into buying a huge ball bearing turbo w/ intercooler, I'm sure he has a built motor with a lower compression ratio to run higher boost numbers. His set-up is a one-off stand alone system that I've neer seen duplicated - he's probably put at least 60K+ into this car (conservatively).
-Chike
Originally posted by Phast SVX
one word.
FRONT MOUNT
oh wajt ahhh
2006 Steel Gray WRX TR (sold)
Old 04-17-2004, 01:56 AM
Phast SVX's Avatar
how do you know what kind of management he has? Also how do you know its a ball bearing cartridge by looking at it?
phil
~Phil
Old 04-17-2004, 02:31 AM
Crash
Considering the amount of the intercooler alone (about $3000.00) I would venture to say it is ball bearing. But it does not look much bigger than the tdo5 I had on my eclipse. It all seems kinda tight. Like an rx-7, the car seems to dissipate heat about as well as an oven. And we all know why rotarys aren't boosted anymore--they overheat and die. I don't feel like spending a fortune to burnout my motor. But I will give a hats off for the effort. The work put into it is beautiful. That is someone who really takes pride in their SVX.
Any ideas on hp output?
Old 04-17-2004, 03:14 AM
FlagstaffSVX's Avatar
FlagstaffSVX FlagstaffSVX is offline
Jedi Member
We have to get this guy on our boards.
-Craig Lowthorp, Flagstaff AZ
'92 LS-L, Black on White, 136k SOLD
'92 LS-L, Black on Silver, 120k SOLD
'01 Legacy Outback, White,
Old 04-17-2004, 09:14 AM
Chiketkd's Avatar
PhastSVX, I don't know. I was only making an educated guess based off of the extensive lengths this guy went through to get an intercooled turbo'd SVX. If I spent 15 grand on a turbo, intercooler, wastegate, piping, etc., I would be foolish not to have a stand alone Engine Management system that would prevent my investment from blowing up! And a built motor to handle high levels of boost would be icing on the cake!
This guy is obviously not hurting for money!
-Chike
phil
Old 04-17-2004, 09:23 AM
Chiketkd's Avatar
I was hoping you might fathom a guess! I pulled my SportCompact Car Magazine featuring the Ultimate Street Car Challenge and looked over the different turbo setups several contestants ran - a big intercooled turbo set-up like this would easily be able to boost hp output by over 150% (based on gains from DSMs, Supras, RX-7's, Skylines).
The base output of the EG33 engine is 230hp, but if he lowered the compression ratio to say 8.5:1 to run higher boost, output would have dropped to 200hp approx (w/o boost). If he is running a conservative boost level of say 1 bar (14.7psi), output could be in 450-500hp range!
-Chike
Old 04-17-2004, 09:53 AM
STORMINORMAN STORMINORMAN is offline
Exclamation Gulp!
"...output could be in 450-500hp range!"
Transmission oughta' handle that with no problems, right?
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 04-17-2004, 09:59 AM
Sonar's Avatar
Sonar Sonar is offline
Nice work, he probably routes the pressure through the other fender and up to the intake.
I have done this type of routing on a XT-4 before, but thru 2 intercoolers, one chargecooler (water cooled), and one ordinary intercooler.
The only drawback with this very long "plumbing" is the "lag" of the system is very noticable, esp. in lower gears.
A very rough rule is 10% for every (inercooled) 0.1 bar
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 04-17-2004, 10:14 AM
Chiketkd's Avatar
Thumbs up
We would still be talking 400hp+ with that equation! I'm sure the transmission has had to be upgraded (maybe even the driveshaft). Thing is...if you have the money and good connections...tuners can fabricate some sweet stuff for you!
-Chike
Old 04-17-2004, 01:49 PM
svxsubaru1's Avatar
You can get a huge inner cooler caple of over 500 horse for about $800 U.S, thats extermely efficent.
Old 04-18-2004, 07:06 PM
marlettpat marlettpat is offline
THE MEMBER
Send a message via AIM to marlettpat Send a message via Yahoo to marlettpat
i think i remember something about this guy before. someone had posted pics of his car before, but he couldnt speak english........i cant remember his handle..!!! uhg
Would love an SVX of my own...
Old 04-18-2004, 07:35 PM
Chiketkd's Avatar
svxsubaru1, I spent a couple of hours searching for intercoolers that were in the $800 range that you mentioned and found none. Typical prices ranged from $1500 to well over $5000. Now I'm not sure if you're referring to a smaller intercooler system that would work on a turbo'd civic, but all large respectable ones made by HKS, Greddy, etc. run at least $1,500. For illustration, the intercooler upgrades offered for the 3000GT VR-4/Stealth by Dynamic Racing can be seen here. And these aren't even the biggest systems available for these cars. And if you look at systems offered for the Supra & Skyline GT-R, the best ones run into 5-6K range.
And the intercooler this guy has on that Turbo'd SVX is pretty large! Crash was being conservative when he said $3,000.00.
-Chike
Old 04-19-2004, 02:20 AM
Crash
the fact still remains imo that this motor runs pretty hot and turbos get'em coooking even hotter. I really don't think this motor can handle that kind of heat (matched with the type of driving one would do with that hp) for very long without a BeCool rad. and some serious cooling work. Am I wrong?
Old 04-19-2004, 07:02 AM
dcarrb dcarrb is offline
-Chike
Geez, man, I just don't get it. For that kind of dough, I'd be driving a different, very sweet SVX every day of the week.
dcb
