phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
too tell you the truth right now all i REALLY need is for my pesky 6500 rpm fuel cut to be changed to 7400, allowing me to retard th exhaust cam a few degrees and shift the powerband up more usuable and,shift at 7 or alittle higher....how much would you charge for a rom that did that?
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. Last edited by Phast SVX; 02-21-2004 at 12:25 AM. |
I'm not sure I'd recomend it but if you did it you'd want the fuel and timing tables expanded too so that they cover up to 7400 rpm's. I'll look at it and see if I think you'll be ok with either the guesses the ecu will make without the expanded tables or if I interpolated (guess) from the existing tables to expand the rpms a little higher. If either is the case I can move the rpm threshold. You'll have to wait for the production run though. I'm going to reserver the prototype boards people who want nitrous kits.
phil
i have full access to a dynojet here, so i might as well make it RWD while i get all this sorted out. Quite a few people are running 100 dry, and i do suspect as you suggest it is running near the duty of the injectors. What has been your analysis as of far. Most of the time im running a 50 dry. If your going to be selling packages maybe i could get the injectors/ecu remap and use my nitrous kit, with the new injectors allowing for plenty of flow when called upon by the fpr(your correct, it merely bumps up fuel pressure) ?
phil
I will be offer a 2nd kit later which includes NISMO 555cc injectors and a dry nitrous system. Because of the injectors though, that kit will cost twice as much. Nismo injectors are expensive and lesser injectors just aren't good enough to consider. The problem with trying to go half and half with the stuff I'm offering and with your kit is that it bumps up the fuel pressure alot and will completely screw up the fuel tuning. I hate to tell you to scrap what you've got but the best thing to do might be ebay your current kit then get the complete set up from us. |
Sure why not, blowing stuff up is cool.
I'm not sure I understand 100%. So I can buy a chip that will provide correct fuel and ign maps to run 100shot of nitrous to 7,400 RPM's? If so what exactly is going to be included with the chip as far as the nitrous kit, and what kinda price and time table are we looking at? Also I assume the maps will have to be based on fuel octain rating right? I run on 93 anyway (used to be 94 but they don't carry it anymore ) so will that be considered? I was very close to getting a Zex kit, like really, really soon. But if this set up is anywhere near compleation or price comparability, I might hold out for a little wile.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
I can't race ya man if ya have Nitrous... that would be an unfair advantage... If ya get that then I'll just forfit
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
why not an even 7500?
All kidding aside, has anyone done any research into what kind of factor of safety the Subaru engineers built into the engine? If the code shows 6700 now, bumping up to 7500 is only a 12% increase. I'm guessing that those of us with automatics will have a little more safety margin due to the dampening effect of the torque convertor (vs the 5spd's clutch).
I'm still sorting out the suspension on my '92, so I'm looking at a couple of months before I'm ready to get into the engine. That said, I'm very interested in the stage 2 system. Any thought of going with the Impreza (?) fpr that Mychailo is running now to go with the NISMO injectors? -Bill (once a Mechanical Engineer, always a Mechanical Engineer - though this ECU stuff has me thinking I should have taken more EE courses! )
I have heard that the Valve system of a relativly new engine (10,000miles ish...) should be good to about 8,000 and maybe even 8,500rpm.... However I would feel better replacing my springs and possibly valves first before I turned over 7,500rpm...
#28
maybe you should contact the guys at pantera, im sure they could give you a better idea of what would be best?
phil
#30
Re: why not an even 7500?
As far as switching the fuel pressure regulator it is uneccasary and a lil contrary to the point. The svx runs at 33 psi which is a good pressure to run the larger NISMO fuel injectors at. Switching to the larger fuel injector is the correct way to get more fuel. Bumping up the fuel pressure is just a bandaid people use to avoid paying for the fuel injectors. |
Thread Tools | |
Display Modes | |
