Water pump replacements?
What do you folks use as a replacement water pump for the SVX?
There are two Subaru part codes that seem relevant: 21111AA033 - this pump is with two outlets 21111AA070 - this pump is with three outlets, with one line going to the oil cooler. There's only one picture of this pump in the internet, and the code is not recognized by Subaru but should be a valid FHI code. So far the two pumps that we've tried are Aisin WPF002 and WPF006. WPF002 does not fit, and has only one outlet, despite marketed as a replacement pump. WPF006 roller would leave about half an inch of the timing belt unsupported, looks like it's too short to be used. I'm aware of GMB160-2050, which seems to be a bit better on how far up the roller reaches. I haven't seen if they have a three outlet version available for the pump. Any tips and ideas what pump would fit from which vendor? We can probably make do with two outlets. Wouldn't want to reuse the old pump, unless I absolutely have to. |
Re: Water pump replacements?
Hello,
Is 21111AA033 no longer available now? According to part list, compatible parts of X211AA000 (water pump kit) are 21111AA033 water pump complete 21114AA051 gasket water pump 21116AA020 sealing water pump 21234AA010 gasket thermostat Also yahoo says https://store.shopping.yahoo.co.jp/i...0bjnmlnsc.html 21111AA033 21111-AA060 21111-AA061 21111-AA062 Genuine 21111-AA062 seems still available. JPY17,900 https://www.monotaro.com/g/04520363/ Also, GWSU-12A of GMB JPY6,390 seems okey. https://www.monotaro.com/p/0992/5772/?t.q=21111AA033 Pls check it. |
Thank you Noriyasu for taking your time to reply.
Apologies for not posting pictures earlier, this should make it a bit easier to see the issue. The SVX in question is MY1992 - as far as I know. Here's the pump from the vehicle, with three outlets, one of them towards the oil cooler. I've added a couple of markers to this photo to show a couple of features of the original pump. Here's WPF006 from Aisin (it has three outlets too), with added markers. The roller in the Aisin pump is not high enough for the timing belt to fully latch on. I'd need to see photos of the water pumps from this angle to check if they actually fit. I don't know if there's something odd in my SVX, or if the oil cooler has been retrofitted into it at some point. Yahoo Japan does not ship goods to European Economic Area, so the link does not open for me. GWSU-12B has one water outlet, we'd prefer a pump with at least two outlets. We can circumvent the need for the third outlet as long as the pump fits. I'd need to get Monotaro's page translated somehow to order something from them. A genuine 21111AA033 does not seem to be available here, but I'll go check from the local Subaru dealer. |
Oh, Finland...
Can you see this ? https://store-shopping-yahoo-co-jp.t..._x_tr_pto=wapp I wrote this just to see compatibility. In the photo, there are only two outlet. I found the photo when I replace the water pump and attach these. mine is '92. Pls refer. outlet seems two except thermostat in this photo too. Also, important distance is from is from the engine block to the top(or bottom) of the pulley. Also, from block to base of idler. Pls try to measure it. It may just be the mounting height of the thermostat cover that is different. It doesn't seem to interfere with the timing belt cover. For the monotaro, it will ship only Japan domestic. I sometimes refer to this shopping site to check if the part has been discontinued or not. Discontinued parts usually appear as such. For reference, it's a little more expensive than buying from a dealer because of the shipping charges. 21111-AA061 seems discontinued. 21111-AA062 seems still available. I'm not sure it shape quite same as AA033 You may able to get from ebay. https://www.ebay.com/itm/225212446610 |
Hi
WPF-008,21111-AA060/061 and GWSU-16A seems does not fit to SVX. See review of amazon. https://www.amazon.com/Aisin-WPF-008.../dp/B008EEYXZW umm. |
Thank you for these checks!
I can see the translated page, but the pictures are not loading. Yes, I'm actually Finnish. Here, Mika is a male name, which has caused a couple of confusions on my travels to Taiwan. Can't imagine what it would be in Japan. We measured the distance from the engine block to the pulley top, WPF006 is about 10 mm shorter. It does look like the pulley height in 21111-061/62 is not high enough as stated in the review. There is an Ebay option of the GMB water pump which seems to be of correct height. In the manufacturer's pictures, it does seem to have similar height. |
So, I sent the question message about compatibility to Yahoo shop with URL of amazon review. In many cases, web shop photos are unreliable. The photos may have been selected by non-experts who do not understand the product well. On the other hand, the Legacy 2.2L model is listed in the product compatibility information on eBay. EG33 has a history of adding two cylinders based on EJ22. Similar parts may have been used on that. What about confirming your eBay shop about compatibility? eBay has a 30-day money back guarantee, so if it doesn't work, you can return it. My SVX's engine was overhauled 4 and a half years ago, so I don't think I'll ever replace the water pump again in the future, but since many parts are discontinued, I think your information would be helpful to everyone. |
Regarding the availability of the genuine 21111AA033 water pump, Subaru Finland says the part is no longer available. Amayama does not list it either.
I have ordered GMB 160-2050 from Ebay, the general prescription is available from the vendor's site here. Fingers crossed that this will fit. I'll let you know how this goes. We're overhauling this EG33 as the head gasket was leaking and pushed the coolant to the expansion tank. The former gaskets were not MLS, and allowed coolant to enter cylinders 5 and 4. Luckily no significant damage to the cylinder walls. It's a thing of its own to repair a 30 year old car with limited production numbers! |
The total production volume was 24,379. Of these, only 5,951 units are registered in Japan.
The authenticity is uncertain, but it seems that the number of registered cars in Japan a few years ago was 865. Due to the discontinuation of many parts, the number seems to be rapidly decreasing as they are unable to pass vehicle inspection. The SVX has a defect where when the electromagnetic clutch of the air conditioner compressor is damaged, the fuse of radiator fan will blow and the radiator fan will not work. In my case, this caused overheating and damage to the head gasket. At that time, the genuine head gasket was already discontinued, so I used Cometic-066-MLS. FYI |
Hello all.
I am also in need of a water pump. Please send leads for finding the right SVX part. Hey Mika, how did the search work out? Any luck with the ebay listing? I'm open to any suggestions. BobSVX96. |
...and on the technical side...
I know that I should IDEALLY put in a new water pump when I service the timing belt...but what's the downside of keeping the current water pump (which has been working fine)? Tks, BobSVX96. |
The water pump will eventually fail and seize up. If the engine is ran after that it will over heat and likely require expensive repairs. There is also risk of water pump derbies getting stuck in hard to clean places.
Usually you will hear noise coming from the pump before complete failure, but I would not count on that as a warning sign. Ebay seems to have a number of Subaru SVX water pumps listed, for example: https://www.ebay.com/itm/225212447283 I don't know if that is a good seller or not, or if they are correctly describing the item for sale. But the bottom line: Don't skip the water pump. |
Tks, Irox. ALWAYS appreciate an expert pov.
Yes, I saw the ebay listing, but I was concerned that the ebay water pump only shows TWO outlets...and I believe our SVX water pumps have THREE outlets. Is this correct? And I thought that the 3rd outlet (the one by itself on the "left" side) went to the oil cooler. Is this correct? Tks for your patience and advice. BobSVX96. |
Hi BobSVX96,
The water in the ebay link I sent has 3 outlets. There are two small outlets, and one big one. All three are visible in the picture in the ad, but it's not obvious that the large hole is another outlet. Note the picture only shows one side, the front, of the pump, and doesn't show the side that mates to the engine (so there is another large hole on the back which isn't shown). Looking at the ebay pic, the large opening to the left side of the pulley is the main outlet. There is another fitting that bolts onto the large opening and allows the large diameter radiator hose to connect to the water pump. Note, you much remove this fitting off of your old water pump and install it on the new pump. Hope that helps! |
Tks, Irox. You are one of the things I love about this forum: pragmatic help with a side of education!
In the spirit of eduction, can you pls look at the picture in the #3 post below...the pic that shows "the pump from the vehicle, with three outlets, one of them towards the oil cooler." If we're counting the large opening by the pulley (the main outlet) as one of the outlets, then aren't there FOUR outlets? In Mika's pic, there's the (#1) large opening, the (#2) outlet that goes to the top of the pic (I think Mika suggests that this goes to the oil cooler), the (#3) left outlet that goes to the bottom of the pic, and (#4) the right outlet that goes to the bottom of the pic. Have I got this wrong? Am I seeing one of these outlets incorrectly? Sorry for my confusion. I humbly ask for a bit more help. Tks again, B. Last edited by BobSVX96; 04-30-2024 at 10:40 PM. Reason: spelling |
